configuration of the time in the case using remote API
SitStudent
Post by SitStudent »
Hi, there
I simulate one scene using remote API and output the graph which has a time as x axis but, considering procedure of using remote API, x axis(time) is from the start of simulation not start of the remote API system .
Therefore, I want to set the start of the x axis on the graph as start of the remote API.
Is there any way for that?
sincerely,
Re: configuration of the time in the case using remote API
currently you can only record graph value when simulation is running unfortunately. But this will be changed in next release (V4.2.0).
SitStudent
Thank you for your reply.
I use a remote api and lua child script on the scene at the same time. Is it possible lua script recognizes the moment remote API is connected on the child script?
I think about using sim.resetGraph.
Sincerely,
Yes, this would be possible. However, there is a bug in current CoppeliaSim V4.1.0, where every graph would be automatically reset at simulation start, which is problematic for you. Next version will have that corrected.
SitStudent
Ok, so...is it possible that you tell me when that will be launched?
If you don't mind, please tell me.
Sincerely,
next release should be out in January/February 2021. In the mean time you can always collect the data and/or transmit it to an external application for display (e.g. Matlab, etc.)
SitStudent
Hi
I updated new version of CoppeliaSim 4.2.0.
Actually, it's more useful for me to set a graph.
I really appreciate for that.
Then, about my topic, is my problem fixed by this new version of CoppeliaSim?
Sincerely,
yes, you can now also record graph data points when simulation is not running. Have a look inside of lua/graph_customization.lua.
SitStudent
Thank you
I saw the scripts inside lua\graph_customization.
However, I've never used these lua files inside CoppeliaSimEdu\lua so I couldn't make sense which scripts I should use.
If you don't mind, could you teach me which scripts I should use?
sincerely,
Open the customization script attached to your graph, then past following code instead:
graph=require('graph_customization')
    graphHandle=sim.getObjectHandle(sim.handle_self)
    -- Create/update data streams/curves:
    sim.destroyGraphCurve(graphHandle,-1)
    stream1=sim.addGraphStream(graphHandle,'Object position X','m')
    objectHandle=sim.getObjectHandle('cube')
    startTime=sim.getSystemTime()
    graph.init()
function appendMeasurementPts()
    -- append measurement points, e.g. the x-position of an object:
    local p=sim.getObjectPosition(objectHandle,-1)
    sim.setGraphStreamValue(graphHandle,stream1,p[1])
    graph.handle(sim.getSystemTime()-startTime)
    graph.updateCurves()
function sysCall_sensing()
function sysCall_nonSimulation()
function sysCall_suspended()
function sysCall_beforeSimulation()
function sysCall_afterSimulation()
function sysCall_suspend()
function sysCall_resume()
In above code, the x-position of object cube will be displayed in the graph. On the x-axis, you'll have the real time, in seconds. When simulation is not running, there will be a new point added only one time every 8 seconds on average. To change that to say 25, do:
sim.setInt32Parameter(sim.intparam_idle_fps,25)
When a change was made in the customization script, make sure you restart it by clicking the restart script button in the script editor.
