an instruction for sim.followPath
quangabcd
Post by quangabcd »
can any body provide an example/instruction how to use sim.followPath (https://www.coppeliarobotics.com/helpFi ... owPath.htm)?
i could not find any path following using this approach
Re: an instruction for sim.followPath
sim.followPath is deprecated and should not be used anymore. If possible, also try to avoid path objects, since they are not that flexible and there will be a better option in next release (i.e. V4.2.0). But for the time being, do something like:
    -- init:
    path=sim.getObjectHandle('myPath')
    pathLength=sim.getPathLength(path)
    -- e.g. place an object at 0.1 meter from the start of the path:
    local dist=0.1
    local relDist=dist/pathLength
    local pos=sim.getPositionOnPath(path,relDist)
    local euler=sim.getOrientationOnPath(path,relDist)
    sim.setObjectPosition(myObjectHandle,pos)
    sim.setObjectOrientation(myObjectHandle,euler)
quangabcd
Post by quangabcd »
Thanks,
the approach with set-get position works
you may need to update the instruction to avoid confusing people ;)
Hrithik Verma
Contact:
Post by Hrithik Verma »
Hello
How to make a object follow path in coppeliasim 4.2.0 (rev5) because the above code is not working and sim.followpath() is already deprecated.
I also tried https://www.coppeliarobotics.com/helpFiles/en/paths.htm follow path method describe in it but that also not working.
I think this particular part should be clearly describe in a post because lots of version having different methods to follow path and people will get lot of confusion.
Thanks in advance
Always make sure to use the newest CoppeliaSim version. In CoppeliaSim V4.2 and V4.3, you'll find a demo scene scenes/movingAlongAPath.ttt: there you will find many different examples on how to have an object follow a path.
