Problem with Instalation
Erfan
Post by Erfan »
I am trying to make a functionality between CoppeliaSim_EDU (version 4.1.0) and ROS noetic on Ubuntu 20.04.
I have followed all instruction posted on:
https://www.coppeliarobotics.com/helpFi ... torial.htm
However, after running the following command:
$ catkin_make --cmake-args -DCMAKE_BUILD_TYPE=Release
I have received an error as:
Base path: /home/erfan/catkin_ws
Source space: /home/erfan/catkin_ws/src
Build space: /home/erfan/catkin_ws/build
Devel space: /home/erfan/catkin_ws/devel
Install space: /home/erfan/catkin_ws/install
#### Running command: "cmake /home/erfan/catkin_ws/src -DCMAKE_BUILD_TYPE=Releas -DCATKIN_DEVEL_PREFIX=/home/erfan/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/erfan/catkin_ws/install -G Unix Makefiles" in "/home/erfan/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/erfan/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/noetic
-- This workspace overlays: /opt/ros/noetic
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.5", minimum required is "3")
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Using Debian Python package layout
-- Using empy: /usr/lib/python3/dist-packages/em.py
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/erfan/catkin_ws/build/test_results
-- Forcing gtest/gmock from source, though one was otherwise available.
-- Found gtest sources under '/usr/src/googletest': gtests will be built
-- Found gmock sources under '/usr/src/googletest': gmock will be built
-- Found PythonInterp: /usr/bin/python3 (found version "3.8.5")
-- Using Python nosetests: /usr/bin/nosetests3
-- catkin 0.8.9
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 2 packages in topological order:
-- ~~ - ros_bubble_rob
-- ~~ - sim_ros_interface
-- +++ processing catkin package: 'ros_bubble_rob'
-- ==> add_subdirectory(ros_bubble_rob)
-- +++ processing catkin package: 'sim_ros_interface'
-- ==> add_subdirectory(sim_ros_interface)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- CoppeliaSim: LIBPLUGIN_DIR: /home/erfan/CoppeliaSim/programming/libPlugin.
-- CoppeliaSim: COPPELIASIM_ROOT_DIR: /home/erfan/CoppeliaSim.
-- Found CoppeliaSim installation at /home/erfan/CoppeliaSim.
-- Checking CoppeliaSim header version...
-- CoppeliaSim headers version 4.1.0 rev1
-- Adding simStubsGen command...
CMake Error at sim_ros_interface/CMakeLists.txt:68 (coppeliasim_add_plugin):
Unknown CMake command "coppeliasim_add_plugin".
-- Configuring incomplete, errors occurred!
See also "/home/erfan/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/erfan/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
Can everybody kundy help me to resolve this issue?
Thank you in advance and regards,
Erfan
Re: Problem with Instalation
Erfan wrote:
23 Mar 2021, 11:55
You need to update your libPlugin repository (located in CoppeliaSim's programming folder) to latest version. And probably also include and common.
