Problem on using URDF
ahmedelwaly
Post by ahmedelwaly »
I am trying to import my robot model using URDF plugin, but when i import, it says
simExtURDF: info: import operation started.
simExtURDF: info: there are 12 joints.
simExtURDF: error: there is no joint with name ''
simExtURDF: info: there are 13 links.
I don't understand the error "ERROR: there is no joint with name ''" .
Do you have any suggestions as to how to import the model correctly?
Re: Problem on using URDF
the error means that the joint does not have any name, in the URDF file. This does not always mean that the file is faulty. But what a simulator expects from a file and what is actually in the file can greatly vary.
Does the import operation produce anything? Or what is the problem, next to the error messages?
fai
Post by fai »
I have the same error message, but the imported model seems right.
My urdf file looks like:
<joint name="Rigid13" type="fixed">
<origin rpy="0 0 0" xyz="0.054297 -0.07 0.1"/>
<parent link="base_link"/>
<child link="Quader1_1"/>
</joint>
<joint name="Rev14" type="continuous">
<origin rpy="0 0 0" xyz="0.217851 0.050972 0.1"/>
<parent link="Quader1_1"/>
<child link="Component4_1"/>
<axis xyz="1.0 0.0 0.0"/>
So, it looks like the name for the joints are well defined. In fact, the imported joints in CoppeliaSim appear with these names. So, is this just a bug in the plugging or should the joints be defined in some other way?
Cheers,
Andres
Hello Andres,
can you post a minimalistic, self-contained URDF file that illustrates this problem?
fai
Post by fai »
Sure! Here you go.
<?xml version="1.0" ?>
<robot name="assembly" xmlns:xacro="http://www.ros.org/wiki/xacro">
<link name="base_link">
  <inertial>
    <origin rpy="0 0 0" xyz="-0.025 0.025 0.1"/>
    <mass value="3.925"/>
    <inertia ixx="0.013901" ixy="-0.0" ixz="-0.0" iyy="0.013901" iyz="0.0" izz="0.001635"/>
  </inertial>
  <visual>
    <origin rpy="0 0 0" xyz="0 0 0"/>
    <geometry>
      <cylinder length="0.6" radius="0.2"/>
    </geometry>
    <material name="silver_default"/>
  </visual>
  <collision>
    <geometry>
    </geometry>
  </collision>
</link>
<link name="box_v2_1">
  <inertial>
    <origin rpy="0 0 0" xyz="0.025 0.024999999999999994 -0.025"/>
    <mass value="0.98125"/>
    <inertia ixx="0.000409" ixy="0.0" ixz="-0.0" iyy="0.000409" iyz="0.0" izz="0.000409"/>
  </inertial>
  <visual>
    <origin rpy="0 0 0" xyz="-0.0 -0.05 -0.0"/>
    <geometry>
      <box size="0.6 0.1 0.2"/>
    </geometry>
  </visual>
  <collision>
    <geometry>
    </geometry>
  </collision>
</link>
<joint name="Rev2" type="continuous">
  <origin rpy="0 0 0" xyz="0.0 0.05 0.0"/>
  <child link="box_v2_1"/>
  <axis xyz="0.0 1.0 0.0"/>
</joint>
</robot>
And this is the output:
simExtURDF: info: there are 1 joints.
simExtURDF: info: there are 2 links.
simExtURDF: info: creating link 'base_link'...
simExtURDF: info: creating link 'box_v2_1'...
simExtURDF: info: there are 0 sensors.
simExtURDF: info: import operation finished.
The loaded model looks fine: two bodies joined with a revolute joint..
Thanks for the file.
Those error messages are actually faulty, and shouldn't show. This is fixed for next release or revision. In the mean time simply ignore them.
