Distortion parameters from vision sensor?
SeveQ
Post by SeveQ »
Hey again,
I'm looking for a way to fill in the sensor_msgs/CameraInfo fields from a vision sensor. What's the best way to get the values for distortion parameters and everything ROS needs in order to work with it?
And thanks again!
Cheers,
Hendrik
Re: Distortion parameters from vision sensor?
Hello Hendrik,
not sure about the distorsion parameter. The vision sensors are software sensors and normally ideal, i.e. no distorsion. I guess it also really depends on what the other application is relying on (what of those parameters the other application is really using), but maybe you can find some answers around OpenGL, since the vision sensors are using it.
SeveQ
Post by SeveQ »
I somehow figured it out myself. The easiest way to get the required parameters is by using camera calibration tools provided by the corresponding ROS package and creating an appropriate checker board in V-REP by hand (I used a texture made with The Gimp).
rick187
Post by rick187 »
Hello Hendrik, you can find a simple way to compute the camera_info for a vision sensor in the ros plugin. In particular in the file ROS_server.cpp you can find the following code:
if (publishers[pubI].cmdID==simros_strmcmd_get_vision_sensor_info)
				int resol[2];
				int handle = publishers[pubI].auxInt1;
				if (simGetVisionSensorResolution(handle,resol)!=-1)
					sensor_msgs::CameraInfo info;
					info.header.stamp = inf.headerInfo.stamp;
					char* objName=simGetObjectName(handle);
					info.header.frame_id = objNameToFrameId(objName);
					simReleaseBuffer(objName);
					info.width = resol[0];
					info.height = resol[1];
					simFloat view_angle = M_PI/4;
					const unsigned int viewing_angle_id = 1004;
					simGetObjectFloatParameter(handle, viewing_angle_id, &view_angle);
					double f_x = (info.width/2.) / tan(view_angle/2.);
					double f_y = f_x;
					info.distortion_model = sensor_msgs::distortion_models::PLUMB_BOB;
					info.D.resize(5);
					info.D[0] = 0;
					info.D[1] = 0;
					info.D[2] = 0;
					info.D[3] = 0;
					info.D[4] = 0;
					info.K[0] = f_x; info.K[1] =   0; info.K[2] = info.width/2;
					info.K[3] =   0; info.K[4] = f_y; info.K[5] = info.height/2;
					info.K[6] =   0; info.K[7] =   0; info.K[8] = 1;
					info.R[0] = 1; info.R[1] = 0; info.R[2] = 0;
					info.R[3] = 0; info.R[4] = 1; info.R[5] = 0;
					info.R[6] = 0; info.R[7] = 0; info.R[8] = 1;
					info.P[0] = info.K[0]; info.P[1] = 0;         info.P[2] = info.K[2]; info.P[3] = 0;
					info.P[4] = 0;         info.P[5] = info.K[4]; info.P[6] = info.K[5]; info.P[7] = 0;
					info.P[8] = 0;         info.P[9] = 0;         info.P[10] = 1;        info.P[11] = 0;
					publishers[pubI].generalPublisher.publish(info);
I have however a related question: how can one set more advanced camera parameters such as different pixel sizes for x and y and non-centered coordinates of the focal axis? This is very important for simulating a real camera for which a simple single focal-length model is not sufficient.
Even the possibility to simulate distortion would be very useful.
I will ask this in a separate faq.
