Can't load XML-Scenes Scince 4.2.0
PvtSchneewitchen
Post by PvtSchneewitchen »
Hi Guys,
since i recently upgrated to Version 4.2.0 it is not possible anymore to load XML-Scenes.
When i try to load a scene the Windows File-Dialog just gives me the possibility to choose ".ttt"-files.
The only thing that still works is loading a XML-Scene programatically.
Have i missed something that this is not possible anymore?
Cheers,
Patrick
Re: Can't load XML-Scenes Scince 4.2.0
Hello Patrick,
that is strange. What revision version do you have?
You can still go [Menu bar --> File --> open scene...] and a load scene dialog will appear, and list all *.ttt and *.simscene.xml files
ray8_3
Post by ray8_3 »
Hi, I am using CoppeliaSim 4.2.0 rev 5 Edu. I am having the same issue. Please see the youtube link below:
indeed, this problem keeps reappearing strangely with specific versions/platforms!
As a workaround you can open the scene with sim.loadScene, or you can create an addon simAddOnXML format loader.lua, place it in the CoppeliaSim folder, with following content:
function sysCall_info()
    return {autoStart=false}
    local file=sim.fileDialog(sim.filedlg_type_load,"XML Format","","","Coppelia XML format","simscene.xml")
    if file then
        sim.loadScene(file.."@keepCurrent")
    return {cmd='cleanup'}
ray8_3
Post by ray8_3 »
coppelia wrote:
13 Aug 2021, 09:15
    if file then
Dear Admin,
Many thanks for your quick reply... Just tried your solution, which solves the problem nicely :-)
Best regards,
Rui
