required python version of simExtROS is different from default in ROS melodic
Posted: 08 Jun 2021, 04:21
I tried to load ros interface plugin, so I git clone and build [simExtROS](https://github.com/CoppeliaRobotics/simExtROS), but have several problems and errors bother me. Here are my environments:
- system: ubuntu 18.04
- ROS: melodic
- CoppeliaSim: V4.2.0
**Question 1:** _can build with python 3, but run with python 2?_
see the dependencies list of [libPlugin](https://github.com/CoppeliaRobotics/libPlugin), **python 3.8 is required**, but the **default version of ROS melodic is python 2.7**, and I tried to build with the default, a python 3 error showed:
```log
CMake Error at /usr/share/cmake-3.20/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find Python3 (missing: Python3_EXECUTABLE Interpreter)
So **I created a python 3 env with conda, and builded successfully**. And run:
```bash
source ~/.bashrc
roscd sim_ros_interface
roscd ros_bubble_rob
``roscd`` the two packages successfully and all is well so far.
Is that right? If so, And why two versions of python are required?
**Question 2:** _plugin 'ROSInterface': load failed_
I copied ``libsimExtROSInterface.so`` to the root folder of CoppeliaSim, create two new terminator (default ros environment, python 2) and then run:
```bash
roscore
```bash
./coppeliaSim.sh
A ros interface error showed:
```log
[CoppeliaSim:loadinfo] plugin 'ROS': load succeeded.
[CoppeliaSim:loadinfo] plugin 'ROSInterface': loading...
[CoppeliaSim:error] plugin 'ROSInterface': load failed (could not load). The plugin probably couldn't load dependency libraries. For additional infos, modify the script 'libLoadErrorCheck.sh', run it and inspect the output.
So I tried to follow the prompt, modified and then run ``./libLoadErrorCheck.sh``, seem no dependency is missing, here is the log:
```log
linux-vdso.so.1 (0x00007f20d2758000)
libimage_transport.so => /opt/ros/melodic/lib/libimage_transport.so (0x00007f20d0eb3000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f20d0caf000)
libtf.so => /opt/ros/melodic/lib/libtf.so (0x00007f20d0a86000)
libroscpp.so => /opt/ros/melodic/lib/libroscpp.so (0x00007f20d06f1000)
librosconsole.so => /opt/ros/melodic/lib/librosconsole.so (0x00007f20d04bb000)
libroscpp_serialization.so => /opt/ros/melodic/lib/libroscpp_serialization.so (0x00007f20d02b8000)
librostime.so => /opt/ros/melodic/lib/librostime.so (0x00007f20d0098000)
libboost_system.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_system.so.1.65.1 (0x00007f20cfe93000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f20cfc74000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f20cf8eb000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f20cf6d3000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f20cf2e2000)
libmessage_filters.so => /opt/ros/melodic/lib/libmessage_filters.so (0x00007f20cf0dd000)
libclass_loader.so => /opt/ros/melodic/lib/libclass_loader.so (0x00007f20ceeb6000)
libroslib.so => /opt/ros/melodic/lib/libroslib.so (0x00007f20ceca3000)
libboost_filesystem.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_filesystem.so.1.65.1 (0x00007f20cea89000)
libtinyxml2.so.6 => /usr/lib/x86_64-linux-gnu/libtinyxml2.so.6 (0x00007f20ce875000)
libconsole_bridge.so.0.4 => /usr/lib/x86_64-linux-gnu/libconsole_bridge.so.0.4 (0x00007f20ce670000)
/lib64/ld-linux-x86-64.so.2 (0x00007f20d2530000)
libtf2_ros.so => /opt/ros/melodic/lib/libtf2_ros.so (0x00007f20ce3c1000)
libtf2.so => /opt/ros/melodic/lib/libtf2.so (0x00007f20ce18d000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f20cddef000)
libxmlrpcpp.so => /opt/ros/melodic/lib/libxmlrpcpp.so (0x00007f20cdbd0000)
libcpp_common.so => /opt/ros/melodic/lib/libcpp_common.so (0x00007f20cd9c5000)
libboost_thread.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_thread.so.1.65.1 (0x00007f20cd7a0000)
libboost_chrono.so.1.65.1 => /usr/lib/x86_64-linux-gnu/libboost_chrono.so.1.65.1 (0x00007f20cd59b000)
librosconsole_log4cxx.so => /opt/ros/melodic/lib/librosconsole_log4cxx.so (0x00007f20cd380000)
librosconsole_backend_interface.so => /opt/ros/melodic/lib/librosconsole_backend_interface.so (0x00007f20cd17e000)
liblog4cxx.so.10 => /usr/lib/x86_64-linux-gnu/liblog4cxx.so.10 (0x00007f20ccdb5000)
libboost_regex.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_regex.so.1.65.1 (0x00007f20ccaad000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f20cc8a5000)
libPocoFoundation.so.50 => /usr/lib/libPocoFoundation.so.50 (0x00007f20cc4fc000)
librospack.so => /opt/ros/melodic/lib/librospack.so (0x00007f20cc2b9000)
libactionlib.so => /opt/ros/melodic/lib/libactionlib.so (0x00007f20cc098000)
libapr-1.so.0 => /usr/lib/x86_64-linux-gnu/libapr-1.so.0 (0x00007f20cbe63000)
libaprutil-1.so.0 => /usr/lib/x86_64-linux-gnu/libaprutil-1.so.0 (0x00007f20cbc38000)
libicui18n.so.60 => /usr/lib/x86_64-linux-gnu/libicui18n.so.60 (0x00007f20cb797000)
libicuuc.so.60 => /usr/lib/x86_64-linux-gnu/libicuuc.so.60 (0x00007f20cb3df000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f20cb16d000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f20caf50000)
libboost_program_options.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_program_options.so.1.65.1 (0x00007f20caccf000)
libpython2.7.so.1.0 => /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 (0x00007f20ca752000)
libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f20ca54b000)
libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007f20ca313000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f20ca0e1000)
libicudata.so.60 => /usr/lib/x86_64-linux-gnu/libicudata.so.60 (0x00007f20c8538000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f20c8335000)
- **Question 3:** _can use libsimExtROSInterface.so of V4.0.0 in V4.2.0?_
Since the required python version of CopperliaSim V4.0.0 is python 2 and same as melodic, so I copied the ``libsimExtROSInterface.so`` builded by simExtROS branch ``coppeliasim-v4.0.0`` to the root folder of CoppeliaSim V4.2.0, and run ``./``, every plugins are load successfully except several warnings:
```log
[CoppeliaSim:loadinfo] plugin 'ROS': loading...
[CoppeliaSim:loadinfo] **plugin 'ROS': load succeeded.**
Plugin 'RosInterface': warning: replaced variable 'simROS'
Plugin 'RosInterface': warning: replaced function 'simROS.subscribe@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownSubscriber@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.subscriberTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.advertise@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownPublisher@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.publisherTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.publish@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.serviceClient@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownServiceClient@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.serviceClientTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.call@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.advertiseService@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownServiceServer@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.serviceServerTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.sendTransform@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.sendTransforms@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportSubscribe@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportShutdownSubscriber@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportAdvertise@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportShutdownPublisher@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportPublish@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getTime@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamInt@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamDouble@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamBool@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamInt@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamDouble@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamBool@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.hasParam@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.deleteParam@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.searchParam@RosInterface'
[CoppeliaSim:loadinfo] **plugin 'ROSInterface': load succeeded.**
Do these warning matter?
- **Tutorial correction required**
[The tutorial](https://www.coppeliarobotics.com/helpFi ... torial.htm) about how to have CoppeliaSim ROS enabled seems a little outdated
> Copy the devel/lib/libsimExtROS.so file to the CoppeliaSim installation folder. The plugin is now ready to be used!
It seems that no ``libsimExtROS.so`` is generated after building, but ``libsimExtROSInterface.so``, and ``libsimExtROS.so`` can be found in the root folder of CopperliaSim in default.
Thanks.
- ROS: melodic
```log
```bash
source ~/.bashrc
```bash
roscore
```bash
./coppeliaSim.sh
```log
```log
```log
Thanks.
