Display text information in scene
pwyq
Post by pwyq »
Hi Coppelia,
I'm wondering if CoppeliaSim has a similar function like QTextEdit in PyQt, which can display large trunk of text in real-time? Essentially I would like to display the info from the status bar in the scene (floating window also works).
I checked `sim.displayDialog`, but it opens new message box everytime and its box size changes based on the length of text.
It would be much appreciated if you may help me on this. Thank you!
pwyq
Re: Display information in scene
Post by pwyq »
I found simTextEditor functions and an example snippet of XML. Is there any way I can append info to the text editor?
I found <text-browser> for simUI.create(). I believe I can update the text by simUI.setText, how should I found the widget ID thou?
pwyq wrote: 09 Jun 2021, 01:15 I found <text-browser> for simUI.create(). I believe I can update the text by simUI.setText, how should I found the widget ID thou?
if your UI XML is:
<ui>
    <text-browser id="1" />
</ui>
then id is 1 :-)
pwyq
Re: Display text information in scene
Post by pwyq »
Hi fferri, Thank you for the great custom UI extension!
please also have a look at sim.auxiliaryConsoleOpen
