Lua Script input and output
zhy149
Post by zhy149 »
Is there a way to do console input in Coppeliasim? Can I open a text file or other files inside a child script and write to a file?
Thank you very much!
Re: Lua Script input and output
If you mean to read standard input, you can do so in a plugin, but it is not recommended as it is not a modular solution (what if another plugin reads from stdin as well?).
If you need input from the user, you can use the UI plugin.
If you need input/output with external applications, you can read/write files in Lua with the io module, or use one of the many means of communication which are often better than text files.
have also a look at sim.textEditorOpen and similar functions.
