[BUILD ISSUE] SimClientApplication
Rufio2790
Post by Rufio2790 »
Dear all,
I'm trying to compile coppeliasim to be used on Debian 10.
I've already been able to compile the coppeliaSim library following the instruction provided (however we use Qt5.15 instead of 5.12 used in version 4.2.0, but I understand that it does not matter if we re-compile everything).
However, when trying to compile the simClienApplication, it tries to download a github project that should be located at "GIT_REPOSITORY" "https://github.com/CoppeliaRobotics/simVariousFiles", which is not found.
Can you help with this?
Thanks in advance!
Re: [BUILD ISSUE] SimClientApplication
thanks for mentioning this. We have made the simVariousFiles repository optional, since it is not really required. Please try again.
