Page 1 of 2
remoteAPI.dll with ARM64
Posted: 24 Jul 2021, 17:10
by RobEng
is there a remoteAPI.dll compatible with ARM64 architecture? We want to use the remoteAPI in our current Unity project (for Hololens2, ARM CPU).
Thank you for any help or possible solution you can offer me
Re: remoteAPI.dll with ARM64
Posted: 27 Jul 2021, 19:36
if you are talking about the legacy remote API, then I believe you should be able to compile it on your platform and it should work fine. Please give it a try and let me know.
Posted: 30 Jul 2021, 10:27
by RobEng
thank you for your reply. Yes, I'm talking about the legacy remote API. Which files exactly do I need to compile? I found a folder called remoteAPI with the files extApi.c, extApi.h, extApiInternal.h, extApiPlatform.c and extApiPlatform.h, as well as a folder called remoteApiBindings.
Many thanks
Posted: 03 Aug 2021, 10:40
by fferri
Have a look at
Enabling the remote API - client side to know which one you need.
Posted: 10 Aug 2021, 18:35
by RobEng
thank you. I tried compiling the files for ARM64, but unfortunately didn't succeed in doing so. When I build it, it creates the dll without any error messages, however when I deploy it to the HoloLens 2, it still can't be found. Since I've never created a .dll file before, I don't know where exactly my mistake originates. Here are the steps I followed (I am using Visual Studio 2019):
1. I created a new dll project called remoteAPI
2. I included the headers (extAPI.h and extAPIPlatform.h) in the pch.h file inside extern "C" {}
3. I renamed the .c files (extAPI.c and extAPIPlatform.c) to .cpp and also placed the code inside extern "C" {}
4. I created a new configuration in the configuration manager and copied the settings from x86
5. In the debug properties under linker/advanced/target machine, I chose MachineARM64(/MACHINE:ARM64)
Do you happen to know what I did wrong, whether I miss any steps / forgot to change some settings, or where I could get some help with this?
Posted: 11 Aug 2021, 12:00
You can directly use the visual studio project files located in
programming/remoteApiBindings/lib (i.e. remoteApiSharedLib-64.vcxproj) to rebuild the
remoteApi.dll library. That's the easiest. It only relies on having additionally following 3 repositories in the
programming folder:
include,
common and
remoteApi.
However if you were already able to build the library, then that should be fine too. Adjust the target machine. Make sure to have the release configuration, otherwise you might need additional dependencies. Finally, when you say
, what does it mean exactly? Not sure what is supposed to load the
remoteApi.dll on that side. But if a library can't be loaded, it is often because it can't be found in the search path, because it was build for another architecture (e.g. 32 vs 64 bit), or because some dependency is missing (you can use
Dependencies to check for that).
Posted: 11 Aug 2021, 16:48
by RobEng
Thank you for your detailed and quick response. I followed your steps, opened the remoteApiSharedLib-64.vcxproj project, changed the platform to ARM64 and made sure that in the preferences C/C++ the three repositories are added to the additoinal include directories (only common was missing). The configuration is on release and the target machine is MachineARM64, but for some reason this results in 6 linking errors (LNK2001).
In the file extApiPlatform.obj, there are following unresolved symbols: close_shared_memory, set_shared_memory_name, map_shared_memory, set_shared_memory_size and destroy_shared_memory (all seem to be defined in shared_memory.c, which is located in common, so all symbols should have already been defined in the build, if I'm not mistaking). Is there an additional directory that I need to include or preference that needs changing for this to work?
To your question, when I was debugging my unity project from the HoloLens, it threw an exception stating that it was unable to load the remoteAPI.dll, as it wasn't found. As you stated I think the reason for this was missing dependencies, as I hadn't included the three libraries, that you mentioned.
Thank you again for taking the time answering my questions
Posted: 12 Aug 2021, 08:11
You have two possibilities:
- either remove and add again the shared_memory.c and shared_memory.h files (not sure why that is, probably a default setting for those files was changed, but can't put the finger on it)
- or add following preprocessor define: DO_NOT_USE_SHARED_MEMORY
You'll then probably also need to add a new ARM64 configuration via the configuration manager, to avoid a linker error like
fatal error LNK1112: module machine type 'x64' conflicts with target machine type 'ARM64'.
Posted: 12 Aug 2021, 13:00
by RobEng
Thank you for the suggestions. When using DO_NOT_USE_SHARED_MEMORY, these errors no longer occur, however I think I've stumbled across a bigger issue.
_WIN32 is defined by C:\Program Files (x86)\Windows Kits\10\Include\10.0.19041.0\shared\minwindef.h which seems to be automatically included by the project (see image below). I assume this causes the previous errors with the shared_memory files and also causes the issues when attempting to use the dll in unity. How come this file is used? Additionally, the supported library can be built for windows, linux and apple, which do I need to choose when building for ARM64? The company I work for is interested in using this for a project and we really appreciate the help here.
#ifdef _WIN32
#define EXTAPI_DLLEXPORT extern __declspec(dllexport)
#endif
#if defined (__linux) || defined (__APPLE__)
#endif
Posted: 13 Aug 2021, 08:51
I would suggest you go another, easier path, since on Windows things can be quite confusing, specially with vs...
Set-up an ubuntu20 (vm) machine for the cross compilation.
Make sure you have the prerequisites:
$ sudo apt install gcc
$ sudo apt install make
$ sudo apt install gcc-aarch64-linux-gnu
$ sudo apt install binutils-aarch64-linux-gnu
Then create file
makeArm64 in
programming/remoteApiBindings/lib/ with following content:
CFLAGS = -Wall -fPIC -static -D__linux
CFLAGS += -DNON_MATLAB_PARSING -DMAX_EXT_API_CONNECTIONS=255
CFLAGS += -I../../include
CFLAGS += -I../../remoteApi
all:
@rm -f lib/*.*
@rm -f *.o
aarch64-linux-gnu-gcc $(CFLAGS) -c ../../remoteApi/extApi.c -o extApi.o
aarch64-linux-gnu-gcc $(CFLAGS) -c ../../remoteApi/extApiPlatform.c -o extApiPlatform.o
aarch64-linux-gnu-gcc $(CFLAGS) -c ../../common/shared_memory.c -o shared_memory.o
@mkdir -p libArm64
aarch64-linux-gnu-gcc *.o -o libArm64/libremoteApi.so -lpthread -lrt -shared
Then from within that folder:
