Python Remote Api - Error with simxCheckDistance call
ask4jubad
Post by ask4jubad »
I am trying to the get the distance between two objects, a robot gripper and a human arm through the python api thus:
_,_, distance_left,_,_= client.simxCheckDistance(gripperHandle, human_hand_left, 0, client.simxServiceCall())
I believe that this is the right way to call the function if I am only
interested in getting the minimum distance.
It doesn't work.
I get this error: ** Leaving... if this is unexpected, you might have to adjust the timeout argument ** at this point.
What's the fix, please? I can't seem to find any helpful detail online.
Re: Python Remote Api - Error with sim call
can you tell me what version of CoppeliaSim you are using, and also what platform?
ask4jubad
Re: Python Remote Api - Error with simxCheckDistance call
Post by ask4jubad »
Here are the setup details:
  • CoppeliaSim Edu, Version 4.2.0
  • Linux Ubuntu 20.04.3 LTS
Do you also have the information about the revision number?
With CoppeliaSim V4.2.0 rev5 I can run simxCheckDistance fine.
ask4jubad
Post by ask4jubad »
I am using v4 but now downloaded v6 and it's still the same issue.
Note that I am using python api and not C.
ask4jubad
Post by ask4jubad »
This is what my basic program looks like:
with b0RemoteApi.RemoteApiClient('b0RemoteApi_V-REP-addOn','b0RemoteApiAddOn', 60) as client:
	_, gripperHandle = client.simxGetObjectHandle("RG2_openCloseJoint",client.simxServiceCall())
	_,humanHandle = client.simxGetObjectHandle("Bill", client.simxServiceCall())
	_,human_hand_left = client.simxGetObjectHandle("Bill_leftHand_tip", client.simxServiceCall())#client to get left hand tip handle
	_,human_hand_right = client.simxGetObjectHandle("Bill_rightHand_tip", client.simxServiceCall())#client to get left hand tip handle
	client.simxStartSimulation(client.simxServiceCall()) #use client to start the simulation
	try:
		while(True):
			_,gripperpose = client.simxGetObjectPosition(gripperHandle, 0, client.simxServiceCall())
			print(gripperpose)
			_,humanpose = client.simxGetObjectPosition(humanHandle, 0, client.simxServiceCall())
			print(humanpose)
			""" placeholders """
			R = gripperpose
			H = humanpose
			calulated_distance = math.sqrt(pow((H[0] - R[0]), 2) + pow((H[1] - R[1]), 2) + pow((H[2] - R[2]), 2))
			print("The calcuated distance between human and robot arm is: ", calulated_distance,  "m")
			#distance between gripper joint and left hand
			check,_,distance_left,_,_ = client.simxCheckDistance(gripperHandle, human_hand_left, -1, client.simxServiceCall())
			print(check)
			print(distance_left)
	except:
		client.simxStopSimulation(client.simxServiceCall())
And this is the output:
importing successful!
Running B0 Remote API client with channel name [b0RemoteApiAddOn]
make sure that: 1) the B0 resolver is running
2) CoppeliaSim is running the B0 Remote API server with the same channel name
Initializing...
Connected!
[1.727636456489563, -0.005904495716094971, 4.065587520599365]
[0.38225793838500977, -0.7649074196815491, 5.134829521179199]
The calcuated distance between human and robot arm is: 1.878671672051633 m
not sure what is going on in your case, but here everything runs fine with the latest CoppeliaSim V4.2.0rev5
But: I see that you are trying to measure a distance between two objects, where the first object is a joint... of course that won't work, because a joint is not a measurable object. Not sure what your second object is (Bill_leftHand_tip) though.
Additionally, you might want to try the ZeroMQ-based remote API instead, which is much easier to use, and gives you access to all of the CoppeliaSim regular API.
ask4jubad
Post by ask4jubad »
Thanks for feedback.
I have selected a dummy object that is measurable on the robot side and it works.
However, for the ZeroMQ api that you recommended, how do I ensure that it running in my simulation window?
Regards
Not sure what you mean... the Zmq remote APi add-on is the server side (loaded by coppeliaSim automatically at start-up, if placed in the same folder), and your python client is simply your python script in the zmqRemoteApi/clients/python folder. On the client side all you have to additionally do, is install zmq and cbor via:
$ python3 -m pip install pyzmq
$ python3 -m pip install cbor
