Bill on path model interaction with objects
Leizah
Post by Leizah »
I'm using the Bill on Path model, I would like to make it pick up some objects from the scene, to carry them along the path and to release them on the floor at the end of the path.
How could I get this kind of interaction? There's some tutorial scene that I could use as reference?
Re: Bill on path model interaction with objects
you can attach the object to the human model via sim.setObjectParent, if the object is not dynamically enabled. Otherwise, you should first attach a force sensor to the human model, and attach the shape to that sensor, also via sim.setObjectParent.
Leizah
Post by Leizah »
Hi, thank you or your answer
Maybe I put the question wrong, I have a Bill on Path model (The one that has also stop points from v2.3) that walks through his path, while the object stands near a certain point of the path (around 30%).
I would like to have that, when Bill reaches the position of the object, he picks up it with both hands. Then, he has to carry this object until he reaches an other point of the path (around 45%), when he has to lift the object in a specific pose.
There is not parent-child relation between Bill and the object, but I've not understood how your solution works...
If you need the human model to move his two hands to pick up something, you'll first have to heavily modify that model. Currently the model does simple keyframe interpolation for the walking movement.
Leizah
Post by Leizah »
Ok, thank you for your reply.
What should I modify in order to get this result or, at least, a pick operation with just one hand?
I don't need the actual pick operation, I just need that the operation looks like a pick, so I could also just set that, when Bill reaches the pick-up point, he extends his arms towards the object and takes this pose until he reaches the lift point.
There's a way to get this?
Leizah
Post by Leizah »
I'm considering the option to split the original path in different sub-paths, in order to obtain the following sequence:
PRESENT SEQUENCE (SINGLE PATH):
- At 30% pick up the object
- At 45% lift the object
- At 75% pick up the object
- At 100% lift the object
PROPOSED SEQUENCE (MULTIPLE PATHS)
PATH 1 (0% to 30% of the single path)
- Bill follows the path using the existing code of the 'Bill on path' model. He then stops at the end of the path.
PATH 2 (30% to 45% of the single path)
- During the walk, Bill arms are placed alongside the bust, with the forearms at 90°, in order to simulate the carry phase. He then stops at the end of the path.
PATH 3 (45% to 75% of the single path)
PATH 4 (75% to 100% of the single path)
Is it possible to make this path-division? And how to manage it into the code?
Thank you for your support
Leizah
Post by Leizah »
Hi, I've tried to develop the solution that I've proposed into the previous answer, but I got some problems related to the time sequence.
Following the tips provided into this topic, I made several wait functions, but the sequence is still "shattered" (Bill continues to walk "invisible" and appears in different positions of the paths).
Also at the beginning of the movements, there are some glitchy movements.
There are 5 subpaths, with the ending point of the n path coincident with the starting point of the n+1 path.
Here's the code I used:
function sysCall_actuation()
        if errorMsg then
function setColor(colorName,color)
    local objectTable=sim.getObjectsInTree(BillHandle,sim.object_shape_type)
    for i=1,#objectTable,1 do
        sim.setShapeColor(objectTable[i],colorName,0,color)
function moveBody(dist)
    if dist then
        local t1=math.mod(dist/1,1)
        local t2=math.mod(t1+0.5,1)
        sim.setJointPosition(legJointHandles[1],sim.getPathInterpolatedConfig(legWaypoints,timings,t1)[1])
        sim.setJointPosition(kneeJointHandles[1],sim.getPathInterpolatedConfig(kneeWaypoints,timings,t1)[1])
        sim.setJointPosition(ankleJointHandles[1],sim.getPathInterpolatedConfig(ankleWaypoints,timings,t1)[1])
        sim.setJointPosition(shoulderJointHandles[1],sim.getPathInterpolatedConfig(shoulderWaypoints,timings,t1)[1])
        sim.setJointPosition(elbowJointHandles[1],sim.getPathInterpolatedConfig(elbowWaypoints,timings,t1)[1])
        sim.setJointPosition(legJointHandles[2],sim.getPathInterpolatedConfig(legWaypoints,timings,t2)[1])
        sim.setJointPosition(kneeJointHandles[2],sim.getPathInterpolatedConfig(kneeWaypoints,timings,t2)[1])
        sim.setJointPosition(ankleJointHandles[2],sim.getPathInterpolatedConfig(ankleWaypoints,timings,t2)[1])
        sim.setJointPosition(shoulderJointHandles[2],sim.getPathInterpolatedConfig(shoulderWaypoints,timings,t2)[1])
        sim.setJointPosition(elbowJointHandles[2],sim.getPathInterpolatedConfig(elbowWaypoints,timings,t2)[1])
        for i=1,2,1 do
            sim.setJointPosition(legJointHandles[i],0)
            sim.setJointPosition(kneeJointHandles[i],0)
            sim.setJointPosition(ankleJointHandles[i],0)
            sim.setJointPosition(shoulderJointHandles[i],0)
            sim.setJointPosition(elbowJointHandles[i],0)
function setPausePointVisibility(l)
    for i=1,#pausePoints,1 do
        local pp=pausePoints[i]
        sim.setObjectInt32Param(pp.handle,sim.objintparam_visibility_layer,l)
function handlePossiblePause_Path_1(op,dist)
    local st=sim.getSimulationTime()
    if op==0 then
            local p=sim.getObjectPosition(pausePoints[i].handle,-1)
            local d=sim.getClosestPosOnPath(path1Positions,path1Lengths,p)
            pausePoints[i].dist=d
            pausePoints[i].visited=false
            if not pp.visited and (op&pp.dir~=0) then
                if (op==1 and dist>pp.dist) or (op==2 and dist<pp.dist) then
                    pp.visited=true
                    local b=sim.getObjectPosition(BillHandle,-1)
                    local dx=p[1]-b[1]
                    local dy=p[2]-b[2]
                    sim.setObjectOrientation(BillHandle,-1,{0,0,math.atan2(dy,dx)})
                    moveBody()
                    sim.wait(pp.duration)
    return sim.getSimulationTime()-st
function handlePossiblePause_Path_2(op,dist)
    if op==0 then
            local d=sim.getClosestPosOnPath(path2Positions,path2Lengths,p)
                    pp.visited=true
                    local dx=p[1]-b[1]
                    local dy=p[2]-b[2]
                    moveBody()
function handlePossiblePause_Path_3(op,dist)
    if op==0 then
            local d=sim.getClosestPosOnPath(path3Positions,path3Lengths,p)
                    pp.visited=true
                    local dx=p[1]-b[1]
                    local dy=p[2]-b[2]
                    moveBody()
function handlePossiblePause_Path_4(op,dist)
    if op==0 then
            local d=sim.getClosestPosOnPath(path4Positions,path4Lengths,p)
                    pp.visited=true
                    local dx=p[1]-b[1]
                    local dy=p[2]-b[2]
                    moveBody()
function handlePossiblePause_Path_5(op,dist)
    if op==0 then
            local d=sim.getClosestPosOnPath(path5Positions,path5Lengths,p)
                    pp.visited=true
                    local dx=p[1]-b[1]
                    local dy=p[2]-b[2]
                    moveBody()
function coroutineMain()
    for journey=1,maxJourneys,1 do
        if journey==1 then
            sim.wait(startPosInitialPause)
            sim.wait(startPosPause)
        handlePossiblePause_Path_1(0)
        handlePossiblePause_Path_2(0)
        handlePossiblePause_Path_3(0)
        handlePossiblePause_Path_4(0)
        handlePossiblePause_Path_5(0)
        local dist=0
        while dist<=path1L do
            local dt=sim.getSimulationTime()-st
            dist=velocity*dt
            st=st+handlePossiblePause_Path_1(1,dist)
            local p=sim.getPathInterpolatedConfig(path1Positions,path1Lengths,dist)
            local pp=sim.getObjectPosition(BillHandle,-1)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            sim.setObjectPosition(BillHandle,-1,p)
            moveBody(dist)
            sim.switchThread()
        -- Hide workpiece
        sim.setIntegerSignal('Enter_Reached',1)
        sim.switchThread()
        while dist<=path2L and dist>path1L  do
            dist=velocity*dt
            st=st+waitFunction_Enter()+handlePossiblePause_Path_2(1,dist)
            local p=sim.getPathInterpolatedConfig(path2Positions,path2Lengths,dist)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            moveBody(dist)
            sim.switchThread()
        -- Hide workpiece
        sim.setIntegerSignal('Object_Reached',1)
        -- Change shirt color
        TorsoOriginalColorData=sim.changeEntityColor(ShirtTorsoHandle,{0.37,0.46,0.74},sim.colorcomponent_ambient_diffuse)
        LeftShoulderOriginalColorData=sim.changeEntityColor(ShirtLeftShoulderHandle,{0.37,0.46,0.74},sim.colorcomponent_ambient_diffuse)
        LeftArmOriginalColorData=sim.changeEntityColor(ShirtLeftArmHandle,{0.37,0.46,0.74},sim.colorcomponent_ambient_diffuse)
        RightShoulderOriginalColorData=sim.changeEntityColor(ShirtRightShoulderHandle,{0.37,0.46,0.74},sim.colorcomponent_ambient_diffuse)
        RightArmOriginalColorData=sim.changeEntityColor(ShirtRightArmHandle,{0.37,0.46,0.74},sim.colorcomponent_ambient_diffuse)
        BeltOriginalColorData=sim.changeEntityColor(ShirtBeltHandle,{0.37,0.46,0.74},sim.colorcomponent_ambient_diffuse)
        sim.switchThread()
        while dist<=path3L and dist>path2L do
            dist=velocity*dt
            st=st+waitFunction_Object_1()+handlePossiblePause_Path_3(1,dist)
            local p=sim.getPathInterpolatedConfig(path3Positions,path3Lengths,dist)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            moveBody(dist)
            sim.switchThread()
        sim.setIntegerSignal('Human_TP',1)
        sim.switchThread()
        while dist<=path4L and dist>path3L do
            dist=velocity*dt
            st=st+waitFunction_Robot()+handlePossiblePause_Path_4(1,dist)
            local p=sim.getPathInterpolatedConfig(path4Positions,path4Lengths,dist)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            moveBody(dist)
            sim.switchThread()
        moveBody()
        sim.setIntegerSignal('Exit_Reached',1)
        sim.wait(goalPosPause)
        local dist=path5L
        while dist>0 do
            dist=path5L-velocity*dt
            st=st+handlePossiblePause_Path_5(2,dist)
            local p=sim.getPathInterpolatedConfig(path5Positions,path5Lengths,dist)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            moveBody(dist)
            sim.switchThread()
        moveBody()
    BillHandle=sim.getObjectHandle('Bill_base')
    legJointHandles={sim.getObjectHandle('Bill_leftLegJoint'),sim.getObjectHandle('Bill_rightLegJoint')}
    kneeJointHandles={sim.getObjectHandle('Bill_leftKneeJoint'),sim.getObjectHandle('Bill_rightKneeJoint')}
    ankleJointHandles={sim.getObjectHandle('Bill_leftAnkleJoint'),sim.getObjectHandle('Bill_rightAnkleJoint')}
    shoulderJointHandles={sim.getObjectHandle('Bill_leftShoulderJoint'),sim.getObjectHandle('Bill_rightShoulderJoint')}
    elbowJointHandles={sim.getObjectHandle('Bill_leftElbowJoint'),sim.getObjectHandle('Bill_rightElbowJoint')}
    neckJoint=sim.getObjectHandle('Bill_neck')
    path1Handle=sim.getObjectHandle('Bill_path_1')
    path2Handle=sim.getObjectHandle('Bill_path_2')
    path3Handle=sim.getObjectHandle('Bill_path_3')
    path4Handle=sim.getObjectHandle('Bill_path_4')
    path5Handle=sim.getObjectHandle('Bill_path_5')
    ShirtTorsoHandle=sim.getObjectHandle('Mesh17')
    ShirtLeftShoulderHandle=sim.getObjectHandle('Group28')
    ShirtLeftArmHandle=sim.getObjectHandle('Group30')
    ShirtRightShoulderHandle=sim.getObjectHandle('Group33')
    ShirtRightArmHandle=sim.getObjectHandle('Group7')
    ShirtBeltHandle=sim.getObjectHandle('Group8')
    pausePoints={}
    pausePoints[1]={handle=sim.getObjectHandle('Bill_Enter_Pause'),duration=3,dir=3}
    pausePoints[2]={handle=sim.getObjectHandle('Bill_Object_Pause_1'),duration=3,dir=3}
    pausePoints[3]={handle=sim.getObjectHandle('Bill_TP_Pause'),duration=3,dir=3}
    pausePoints[4]={handle=sim.getObjectHandle('Bill_Object_Pause_2'),duration=3,dir=0}
    setPausePointVisibility(0)
    StandHandle=sim.getObjectHandle('Stand_Enter')
    -- Path_1
    local path1Data=sim.unpackDoubleTable(sim.readCustomDataBlock(path1Handle,'PATH'))
    local m=Matrix(#path1Data//7,7,path1Data)
    path1Pose=sim.getObjectPose(path1Handle,-1)
    path1Positions=m:slice(1,1,m:rows(),3):data()
    path1Positions=sim.multiplyVector(path1Pose,path1Positions)
    path1Lengths,path1L=sim.getPathLengths(path1Positions,3)
    -- Path_2
    local path2Data=sim.unpackDoubleTable(sim.readCustomDataBlock(path2Handle,'PATH'))
    local m=Matrix(#path2Data//7,7,path2Data)
    path2Pose=sim.getObjectPose(path2Handle,-1)
    path2Positions=m:slice(1,1,m:rows(),3):data()
    path2Positions=sim.multiplyVector(path2Pose,path2Positions)
    path2Lengths,path2L=sim.getPathLengths(path2Positions,3)
    -- Path_3
    local path3Data=sim.unpackDoubleTable(sim.readCustomDataBlock(path3Handle,'PATH'))
    local m=Matrix(#path3Data//7,7,path3Data)
    path3Pose=sim.getObjectPose(path3Handle,-1)
    path3Positions=m:slice(1,1,m:rows(),3):data()
    path3Positions=sim.multiplyVector(path3Pose,path3Positions)
    path3Lengths,path3L=sim.getPathLengths(path3Positions,3)
    -- Path_4
    local path4Data=sim.unpackDoubleTable(sim.readCustomDataBlock(path4Handle,'PATH'))
    local m=Matrix(#path4Data//7,7,path4Data)
    path4Pose=sim.getObjectPose(path4Handle,-1)
    path4Positions=m:slice(1,1,m:rows(),3):data()
    path4Positions=sim.multiplyVector(path4Pose,path4Positions)
    path4Lengths,path4L=sim.getPathLengths(path4Positions,3)
    -- Path_5
    local path5Data=sim.unpackDoubleTable(sim.readCustomDataBlock(path5Handle,'PATH'))
    local m=Matrix(#path5Data//7,7,path5Data)
    path5Pose=sim.getObjectPose(path5Handle,-1)
    path5Positions=m:slice(1,1,m:rows(),3):data()
    path5Positions=sim.multiplyVector(path5Pose,path5Positions)
    path5Lengths,path5L=sim.getPathLengths(path5Positions,3)
    velocity=1
    setRandomColors=false
    startPosInitialPause=0
    startPosPause=3
    goalPosPause=3
    maxJourneys=99999
    -- Now we set random colors:
    HairColors={4,{0.30,0.22,0.14},{0.75,0.75,0.75},{0.075,0.075,0.075},{0.75,0.68,0.23}}
    skinColors={2,{0.91,0.84,0.75},{0.52,0.45,0.35}}
    shirtColors={5,{0.37,0.46,0.74},{0.54,0.27,0.27},{0.31,0.51,0.33},{0.46,0.46,0.46},{0.18,0.18,0.18}}
    trouserColors={2,{0.4,0.34,0.2},{0.12,0.12,0.12}}
    shoeColors={2,{0.12,0.12,0.12},{0.25,0.12,0.045}}
    if setRandomColors then
        math.randomseed(sim.getFloatParam(sim.floatparam_rand)*10000) -- each lua instance should start with a different and 'good' seed
        setColor('HAIR',HairColors[1+math.random(HairColors[1])])
        setColor('SKIN',skinColors[1+math.random(skinColors[1])])
        setColor('SHIRT',shirtColors[1+math.random(shirtColors[1])])
        setColor('TROUSERS',trouserColors[1+math.random(trouserColors[1])])
        setColor('SHOE',shoeColors[1+math.random(shoeColors[1])])
    -- Data for body movement:
    timings={0,1/21,2/21,3/21,4/21,5/21,6/21,7/21,8/21,9/21,10/21,11/21,12/21,13/21,14/21,15/21,16/21,17/21,18/21,19/21,20/21,21/21}
    legWaypoints={0.237,0.228,0.175,-0.014,-0.133,-0.248,-0.323,-0.450,-0.450,-0.442,-0.407,-0.410,-0.377,-0.303,-0.178,-0.111,-0.010,0.046,0.104,0.145,0.188,0.237}
    kneeWaypoints={0.282,0.403,0.577,0.929,1.026,1.047,0.939,0.664,0.440,0.243,0.230,0.320,0.366,0.332,0.269,0.222,0.133,0.089,0.065,0.073,0.092,0.282}
    ankleWaypoints={-0.133,0.041,0.244,0.382,0.304,0.232,0.266,0.061,-0.090,-0.145,-0.043,0.041,0.001,0.011,-0.099,-0.127,-0.121,-0.120,-0.107,-0.100,-0.090,-0.133}
    shoulderWaypoints={0.028,0.043,0.064,0.078,0.091,0.102,0.170,0.245,0.317,0.337,0.402,0.375,0.331,0.262,0.188,0.102,0.094,0.086,0.080,0.051,0.058,0.028}
    elbowWaypoints={-1.148,-1.080,-1.047,-0.654,-0.517,-0.366,-0.242,-0.117,-0.078,-0.058,-0.031,-0.001,-0.009,0.008,-0.108,-0.131,-0.256,-0.547,-0.709,-0.813,-1.014,-1.148}
function waitFunction_Enter()
        sim.waitForSignal('Enter_Reached')
 function waitFunction_Object_1()
        sim.waitForSignal('Object_Reached')
function waitFunction_TP()
        sim.waitForSignal('TP_Reached')
function waitFunction_Robot()
        sim.waitForSignal('Robot_Finish')
        if errorMsg then
function sysCall_cleanup()
    setPausePointVisibility(1)
    -- Restore to initial colors:
    setColor('HAIR',HairColors[2])
    setColor('SKIN',skinColors[2])
    setColor('SHIRT',shirtColors[2])
    setColor('TROUSERS',trouserColors[2])
    setColor('SHOE',shoeColors[2])
I hope someone can help me.
Cheers.
Hello again,
you will likely get more replies if you post a simple, short question. Expecting people to read through your algorithm, understand it, reproduce and test it, does usually lead to very few replies, because people willing to spend more than 5 minutes on a reply are rare.
cheers
Leizah
Post by Leizah »
coppelia wrote:
04 Oct 2021, 08:55
Hello again,
cheers
Hello, thank you for your advice.
I'm sorry for posting all the code, but I didn't know where the problem was, so I was not able to select the right strings to show. After the previous two unaswered short questions, I tried to give more information in order to find some help.
However, I'm still dealing with this scene. Can I set that Bill's arms are in a specific pose (arms alongside the torso, forearm at 90°) during the walk?
