frequency of different sensor
panecho
Post by panecho »
Do coppeliasim execute different child scripts at the same rate that specfied at the top of UI?
For if i have IMU and laser work in the same scene, Is it possible to execute the child scripts associated to corresponding sensor object at it's own rate independently?
Re: frequency of different sensor
yes, you are in full control about at which rate you want to execute and/or read things. First of all, during a simulation, there are two callback functions of particular interest:
  • sysCall_actuation()
  • sysCall_sensing()
Both are called in each simulation step. By default, this is every 50 ms. First, then actuation callback is called by the system, then the sensing callback.
For instance, if you want to check for collision between two objects in every simulation step, you'd simply do:
    object1=sim.getObjectHandle("shape1")
    object2=sim.getObjectHandle("shape2")
function sysCall_sensing()
    local result=sim.checkCollision(object1,object2)
    print(result)
If however you want to check for collision in every other simulation step (i.e. half of the time only), you could do:
    cnt=0
    cnt=cnt+1
    if cnt==2 then
        cnt=0
        print(result)
Proximity sensors are implicitly handled in each simulation step by default. But you can also explicitly handle them by checking their Explicit handling checkbox. Then, you can also do something like:
    sensorHandle=sim.getObjectHandle('myProxSensor')
    objectTodetect=sim.getObjectHandle('aRandomShape')
    -- sim.setExplicitHandling(sensorHandle,1) -- here via API, but via GUI also possible
    cnt=0
    cnt=cnt+1
    if cnt==2 then
        cnt=0
        local result=sim.checkProximitySensor(sensorHandle,objectTodetect)
        print(result)
