Run without GUI
VrepOuni
Run without GUI
Post by VrepOuni »
Could CoppeliaSim run without gui? I mean the program could communicate with remoteAPI like python or MATLAB normally but without a user interface.
Re: Run without GUI
yes, you can start CoppeliaSim in headless mode with the -h command line argument. You can also use the purely headless library, coppeliaSimHeadless.dll (or similar), instead of coppeliaSim.dll: in that case however, you won't be able to use vision sensors, unless they render via software, e.g. via the pov-ray plugin. Eventually, you should also be able to perform remote rendering via a connection to a browser that acts as a rendering server.
In headless mode, you will then need to select one or several means of communication with CoppeliaSim (WebSockets will be added for next release).
VrepOuni
Re: Run without GUI
Post by VrepOuni »
Thanks a lot! The help files you provided are very useful.
yifanzhou
Re: Run without GUI
Post by yifanzhou »
I wonder if I can start CoppeliaSim in headless mode with the -h command line argument in a cloud server?
Re: Run without GUI
Please have a look at this topic.
