Calculating Jacobian matrix
inje
Post by inje »
I'm a beginner in V-REP and I have been trying to make a custom controller which is including force control and PD control in Cartesian coordinate
For the first step, applying joint PD control of UR5 was successful, so I tried to get Jacobian matrix. In my case, I need Jacobian matrix for every step to calculate (J^T)F.
I read some documents as below:
https://www.coppeliarobotics.com/helpFi ... ements.htm
https://www.coppeliarobotics.com/helpFi ... Plugin.htm
https://forum.coppeliarobotics.com/viewtopic.php?t=5487
, however, I met a problem
I used sim.getIKGroupMatrix after making dummies in IK mode, an error occurred such that
- IK group does not exist. (in function 'sim.getIkGroupMatrix')
I upload my file that I'm working on, and I want to get feedback to calculate Jacobian matrix. The problem was in 134 row in child script
https://drive.google.com/file/d/1kOtjgf ... sp=sharing
Re: Calculating Jacobian matrix
since CoppeliaSim V4.2.0, you should create IK tasks via the API: this is quite straightforward, and gives you much more flexibility, also allowing to debug problems faster. This means that all FK/IK related functionality now is handled via the kinematics plugin, which exports API functions under the simIK.* namespace. The mentioned page illustrates the approach with a simple example. You can find many more examples in the folder scenes/kinematics.
SevenTRI
Post by SevenTRI »
inje wrote: 11 Nov 2021, 08:24 Hello,
Excuse me, have you solved this problem? How to get the Jacobian matrix of UR5 and DH parameters? Thanks in advance.
With CoppeliaSim V4.5, you can now directly display the Jacobian via [Menu bar --> Tools --> Visualize IK world]. The DH creator and extractor add-ons have also been improved.
But keep in mind, a same kinematic chain has an infinite different DH parameters possible, depending on how the joint locations/orientations was selected.
