How to export URDF from the scene
yifanzhou
Post by yifanzhou »
Dear all,
I wonder if it is possible to export URDF from the scene?
Re: How to export URDF from the scene
see simURDF.export(modelHandle,filename)
yifanzhou
Post by yifanzhou »
Sorry, I can't find any guide about simURDF.export(modelHandle,filename).
The URDF exporter can be used from the main menu (Plugin or Modules menu, depending on your CoppeliaSim version), or you can use it in a Lua script, e.g.:
modelHandle=sim.getObjectHandle('IRB140')
filenames=simUI.fileDialog(simUI.filedialog_type.save,'Save URDF...','','export.urdf','URDF Files','urdf')
if filenames then
    simURDF.export(modelHandle,filenames[1])
you can also download the beta version of CoppeliaSim's next release, which has an improved URDF importer/exporter.
Juancho
Post by Juancho »
Dear Coppelia,
I would like to export my CoppeliaSim scene to URDF. I was wondering if it is possible. Furthermore, I would like to test the beta version of CoppeliaSim, the one that has an improved URDF exporter. However, the link (https://coppeliarobotics.com/files/beta/) does not show some available files.
Thank you for your help.
Best regards,
Juan
Hello Juan,
the URDF exporter is available in current CoppeliaSim version 4.3.rev10 that you can download from the download section. In there, simply select [Menu bar --> Modules --> Exporters --> URDF exporter] and follow the instructions: i.e. you'll have to select a model, and make sure the base of the model is a shape. If you do this, a UI button appears that you can click for the export. You cannot directly export the whole scene. But you can try to add a shape (e.g. sphere), mark it as model base, then attach all object from the scene on top of that sphere, and export that sphere model.
TomDelaney
Post by TomDelaney »
I was wondering when exporting a model into an urdf files is there a way to keep the dummies?
Thank you for your answer!
URDF doesn't know what a dummy is. When exporting (with V4.5), a dialog will appear with an option Make red cubes from dummies: if checked, the URDF file will contain red cubed instead of dummies.
