How to show the trajectory curve of the end-effector of manipulator?
zhangm365
Post by zhangm365 »
HELLO,
How to display the trajectory curve of the end-effector of manipulator in the latest version of the software (V4.2) ?
Re: How to show the trajectory curve of the end-effector of manipulator?
the easiest would be to add a dummy to your scene, attach it to the end-effector, then attach following child script to the dummy:
    h=sim.getObjectHandle(sim.handle_self)
    dr=sim.addDrawingObject(sim.drawing_lines|sim.drawing_cyclic,2,0,-1,500,{1,0,1})
    pt=sim.getObjectPosition(h,-1)
function sysCall_sensing()
    local l={pt[1],pt[2],pt[3]}
    l[4]=pt[1]
    l[5]=pt[2]
    l[6]=pt[3]
    sim.addDrawingObjectItem(dr,l)
zhangm365
Post by zhangm365 »
Thank your prompt reply.
Why does the displayed trajectory disappear automatically?
Can it be retained?
Yes you can increase drawing object maxItemCount, which is the 5th argument of sim.addDrawingObject, and you can explicitly clear the drawing object with sim.addDrawingObjectItem(dr,nil)
zhangm365
Post by zhangm365 »
ok, thanks your reply.
As scripts pointed out int the figure:
https://vrep.oss-cn-shenzhen.aliyuncs.c ... RjNjk4N2Fi
Can the variables between two child scripts, as the picture showed, identify each other?
Yes. One way is to use signals.
You can set a signal in one script, and read the signal with the same name in the other script.
Related API functions:
  • sim.setIntegerSignal / sim.getIntegerSignal / sim.clearIntegerSignal
  • sim.setFloatSignal / sim.getFloatSignal / sim.clearFloatSignal
  • sim.setDoubleSignal / sim.getDoubleSignal / sim.clearDoubleSignal
  • sim.setStringSignal / sim.getStringSignal / sim.clearStringSignal
  • sim.getSignalName
  • sim.waitForSignal
More types of data can be exchanged by packing/unpacking data.
You can also use custom data attached to objects.
