Camera stream of a real Intel Realsense reversed
Marcelbgit
Post by Marcelbgit »
Dear CoppeliaSim community,
right now I am trying to subscribe a camera stream via ROS as you can see in the image below. However, as can be seen in the picture, the real camera (using ROS API) is inverted in contrast to the upper virtual camera (can also be seen in the writing of the pen). To correct this, I can't find any options in the vision sensor settings, etc. Do you have any idea how I can solve this? The stream outputs a "correctly aligned" image, as opening the "camera/color/image_raw" topic in RVIZ (ROS) confirms this. Additionally also my camera settings as further information. One more thing, is there any way to resize a 640x480 pixel camera resolution image to 128x128 via CoppeliaSim?
https://we.tl/t-uaqCbusx2T
I am very grateful for your help!
Cheers,
Marcel
Re: Camera stream of a real Intel Realsense reversed
What can be seen in the image?
I see two very different pictures in the floating views. Is something missing?
Anyways, the reference frame for cameras and vision sensors in CoppeliaSim is set so that \(Y\) points upwards, and \(Z\) points in the direction the object is looking at, therefore the \(X\) axis has to be \(Y \times Z\) (to make a right-handed frame). This usually turns out to be the opposite if what is commonly found in other visualization systems such as WebGL and ROS, so you end up with a flipped image (a flip option in the object could be useful perhaps).
The image however can be transformed via sim.transformImage and scaled via sim.getScaledImage.
Marcelbgit
Thanks for your answer and your help!
The image was meant to show the difference between the image of the "real" and "virtual" camera. The real one was inverted what I didn't get in the past. Now I got the different frame approaches between ROS and CoppeliaSim.
Regarding the sim.transformImage. Does it only work for publishing images? It worked fine for the publishing part but not to flip the image in the subscribed image. I have tried to put it into the callback function to flip the subscribed image like the following lines without success.
function imageMessage_callback(msg)
    local data,w,h=sim.getVisionSensorCharImage(passiveVisionSensor)
    sim.transformImage(data,{w,h},2)
    sim.setVisionSensorCharImage(passiveVisionSensor,msg.data)
in your code above, you should transform msg.data instead of data, e.g.:
    sim.transformImage(msg.data,{msg.width,msg.height},2)
Marcelbgit
thank you so much!
