ZeroMQ non blocking example error
pwyq
Post by pwyq »
I am trying to switch from Python Legacy Remote API to ZeroMQ as suggested, but I have encountered a bit more resistence than expected. One of the problems I would like to ask for help:
While I tried to run code from "simpleTest-nonBlocking.py" and with example scene "controlledViaZmq.ttt", I got the following error and I couldn't find a solution online.
Program started
  File "/home/....../zeromq_nonblocking.py", line 92, in <module>
    asyncio.run(mainFunc())
  File "/home/....../lib/python3.9/asyncio/runners.py", line 44, in run
    return loop.run_until_complete(main)
  File "/home/....../lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete
    return future.result()
  File "/home/....../zeromq_nonblocking.py", line 23, in mainFunc
    async with RemoteAPIClient() as client:
AttributeError: __aenter__
Could you provide some hints on how to resolve this issue? Thank you.
Re: ZeroMQ non blocking example error
simpleTest-nonBlocking.py appears to work fine here (tested with Python 3.8 and 3.9).
Please post the content of /home/....../zeromq_nonblocking.py and provide additional details about your setup (OS, python version, ....).
pwyq
Post by pwyq »
I just renamed simpleTest-nonBlocking.py to zeromq_nonblocking.py and changed the import path of zmqRemoteApi for my own workspace. Nothing else.
OS: Ubuntu 18.04.6 LTS
Python: 3.9.7
CoppeliaSim: V4.3.0 (rev. 3) flavor: 1
A new minimal conda environment is used for this task. Conda config:
channels:
  - defaults
dependencies:
  - _libgcc_mutex=0.1
  - _openmp_mutex=4.5
  - ca-certificates=2021.10.26
  - certifi=2021.10.8
  - ld_impl_linux-64=2.35.1
  - libffi=3.3
  - libgcc-ng=9.3.0
  - libgomp=9.3.0
  - libstdcxx-ng=9.3.0
  - ncurses=6.3
  - openssl=1.1.1m
  - pip=21.2.4
  - python=3.9.7
  - readline=8.1.2
  - setuptools=58.0.4
  - sqlite=3.37.2
  - tk=8.6.11
  - tzdata=2021e
  - wheel=0.37.1
  - xz=5.2.5
  - zlib=1.2.11
  - pip:
    - cbor==1.0.0
    - pyzmq==22.3.0
Looks like you are using the non-asyncio client (due to __aenter__ not being found).
But didn't provide enough details to reproduce your problem.
