Vision sensor picking up shapes even though their visibility layers are all off
cleu892
Post by cleu892 »
I have built a custom robot in CoppeliaSim by first creating the base shapes and joints in CoppeliaSim, and then importing my CAD files of the robot as meshes and putting them on top of the base robot. I have hidden the base robot (unticked all of the camera visibility layers for every part that I want to hide) so that only the detailed CAD robot is shown.
When I look at my DefaultCamera, I can not see any of my hidden shapes. However, my vision sensor is still picking up the shapes of the basic model - how should I go about hiding them from this sensor? I read some previous posts and have made my vision sensor "explicit handling" and added a child script with:
    -- do some initialization here
        h=sim.getObjectHandle(sim.handle_self)
function sysCall_sensing()
    -- put your sensing code here
    sim.handleVisionSensor(h)
But wasn't quite sure where to go from here, or if this was relevant.
Thanks!
Re: Vision sensor picking up shapes even though their visibility layers are all off
what CoppeliaSim version are you using?
cleu892
Post by cleu892 »
I am using Version 4.3.0 (Rev 3) built Feb 11 2022.
That is strange: vision sensors should see the same shapes as cameras. In the past, there was a renderable flag specific to vision sensors. Can you share the scene file, so that we can have a look at it?
You have 5 vision sensors in the scene. All appear to be operating as expected... i.e. not seeing any hidden shapes.
Can you tell me: 1) which sensor is not operating as expected, and 2) what is the expected image from that sensor?
Edit: now I see it. You have revision 3. Please download revision 5 from here, that should fix the problem
cleu892
Post by cleu892 »
Hi again,
Thank you very much! I will do that.
Cheers~
cleu892
Post by cleu892 »
Hi there, just a follow up question, how do I use the CoppeliaSim_Edu_V4_3_0_rev5_macOS10_15 folder from the link you've sent earlier? Do I need to move it somewhere or download something else before my CoppeliaSim updated to Rev 5?
Simply download the last CoppeliaSim package from here. Now we have rev. 10. Remove your previous installation beforehand.
