CoppeliaSim Edu installation errors on Windows 10
catsquito
Post by catsquito »
Hi Team,
I have a hard time installing CoppeliaSim Edu on Windows 10.
Cannot install exe file
I couldn't install CoppeliaSim 4.3.0 edu:
I downloaded CoppeliaSim_Edu_V4_3_0_Setup exe file, and double-clicked it, however below two error messages came out:
Error 1:
It says:
"Setup.txt Script file not found. Setup Aborted!"
Error2:
It says:
"Setup.txt Unable to save Extracted File!
The handle is invalid
Data size: 140018 Bytes
File Size: 0 bytes
Bytes Free: 533590335488 Bytes."
Can anyone help with it?
Cannot use binary package
Alternatively, because installing exe file doesn't work, I downloaded CoppeliaSim 4.3.0 binary package, but after unzipping the package, I don't know where to start: there are so many files, which one should I click to enable the CoppeliaSim interface?
I tried to double-click coppeliaSim.exe, it came out a command line window saying:
"Must construct a QApplication before QWidget!"
What does this mean?!
This software is so hard to install!
Anyone can help me?? Any installation tutorials?
catsquito
Re: CoppeliaSim Edu installation errors on Windows 10
Post by catsquito »
update:
I don't really know how this works, but I installed CoppeliaSim Edu on a different computer, successfully!
The previous errors are most likely because the first computer I tried on belongs to the university, and it has system settings which may be very different from a personal device.
Additionally, when you do not use the installer, you will need to first run <CoppeliaSimFolder>/vcRedist/vc2019redist_x64.exe: this will install basic required items.
