Moving an Object with Lua Code
Luis Nieto
Post by Luis Nieto »
Hello! I would like to ask what is the proper syntax for the position value/s in the sim.setObjectPosition command. I would like to rectangularly translate my mesh part during a simulation which is why I am asking. Thanks in advance.
Re: Moving an Object with Lua Code
The function arguments are described here: sim.setObjectPosition
The position value is {x,y,z}
By the way, sim.setObjectPosition will jump to the set position. If you are looking for a smooth continuous motion, then use sim.moveToPose, e.g.:
function coroutineMain()
    local waypoints={
        -- define a square. waypoints are {x,y,z,qx,qy,qz,qw}
        {0,0,0,0,0,0,1},
        {1,0,0,0,0,0,1},
        {1,1,0,0,0,0,1},
        {0,1,0,0,0,0,1},
    for n=1,100 do
        for i=1,#waypoints do
            local from,to=waypoints[i],waypoints[i%4+1]
            sim.moveToPose(-1,from,{0.8},{0.02},{0.01},to,function(currentPose,currentVel,currentAccel,auxData)
                sim.setObjectPose(self,-1,currentPose)
            end,nil,{1,1,1,0.1})
    self=sim.getObject'.'
function sysCall_actuation()
        if errorMsg then
Luis Nieto
So this sample code would be able to move the object named 'self' through a square-shaped trajectory? Is that correct?
Yes.
See also the examples in the scenes/trajectoryAndMotion/ folder that comes with CoppeliaSim.
Luis Nieto
I would just like to clarify Euler angles:
Alpha is about x, beta is about y and gamma is about z? Is this correct?
Luis Nieto
Also, since you gave me a sample algorithm to do smooth movement of an object during a simulation,
how about doing smooth rotation during a simulation? Is it possible to execute that?
Thanks in advance.
Yes, in the same way. Simply use a different orientation (quaternion) than 0,0,0,1.
Euler angles are explained here: https://www.coppeliarobotics.com/helpFi ... Angles.htm
Luis Nieto
I wish you could also explain this waypoint arrays in the sample code please.
local waypoints={
{0,0,0,0,0,0,1},
{1,0,0,0,0,0,1},
{1,1,0,0,0,0,1},
{0,1,0,0,0,0,1},
for n=1,100 do
local from,to=waypoints,waypoints[i%4+1]
sim.moveToPose(-1,from,{2},{2},{0.01},to,function(currentPose,currentVel,currentAccel,auxData)
Like, how did this
{0,0,0,0,0,0,1}
make a trajectory for the moving object which was going exactly the +x direction?
The waypoints are defined as poses: position + orientation. The position are the (x, y, z) coordinates. The orientation is expressed as a quaternion (qx, qy, qz, qw).
See also sim.buildPose, sim.getObjectPose, sim.setObjectPose
Luis Nieto
How do you manipulate the quaternion to get negative rotation?
For example, I know that for it to rotate about x the quarternion is {1,0,0,0}.
I thought maybe making it {-1,0,0,0} would make it rotate opposite when it was a one I cited above, but it did not.
