How to show pointcloud msg from ROS
liyinghui
Post by liyinghui »
I want to show the point cloud msg in vrep which is from ROS, what should i do? Actually, i m new to that and I could get the pointcloud image in rviz. But I want to show it in vrep so that i could simulate my robot with the pointcloud data.
Re: How to show pointcloud msg from ROS
from the top of my head, something like:
-- Subscribe:
sub=simROS.subscribe('/ptcloud', 'sensor_msgs/PointCloud', 'ptcloudMessage_callback')
-- Subscriber callback:
function ptcloudMessage_callback(msg)
    sim.removePointsFromPointCloud(ptCloudHandle,0,nil,0)
    local pts={}
    for i=1,msg.points,1 do
        pts[#pts+1]=msg.points[i].x
        pts[#pts+1]=msg.points[i].y
        pts[#pts+1]=msg.points[i].z
    sim.insertPointsIntoPointCloud(ptCloudHandle,0,pts)
Keep in mind that the point cloud object must already be created, and that with above code things can get quite slow with larger point clouds. Another message could be more convenient, i.e. one that has all point data inside of a single float array.
liyinghui
Post by liyinghui »
Glad to receive your reply! And i have tried it:
    -- pc=sim.createPointCloud(0.01,1000,0,2)
    -- Get some handles:
    pc=sim.getObjectHandle('Point_cloud')
    -- Enable an image publisher and subscriber:
    if simROS then
        sim.addLog(sim.verbosity_scriptinfos,"ROS interface was found.")
        sub=simROS.subscribe('/points2', 'sensor_msgs/PointCloud2', 'PcMessage_callback')
        -- simROS.subscriberTreatUInt8ArrayAsString(sub) -- treat uint8 arrays as strings (much faster, tables/arrays are kind of slow in Lua)
        sim.addLog(sim.verbosity_scripterrors,"ROS interface was not found. Cannot run.")
function PcMessage_callback(msg)
    -- Apply the received image to the passive vision sensor that acts as an image container
    sim.removePointsFromPointCloud(pc,0,nil,0)
    local pts={}
    sim.insertPointsIntoPointCloud(pc,0,pts)
function sysCall_cleanup()
    if simROS then
        -- Shut down publisher and subscriber. Not really needed from a simulation script (automatic shutdown)
        simROS.shutdownSubscriber(sub)
I have set one pointcloud, and implement the code above. But the scene stuck with the errors:
[sandboxScript:info] Simulation started.
[Point_cloud@childScript:info] ROS interface was found.
[Point_cloud@childScript:error] 30: 'for' limit must be a number
stack traceback:
[string "Point_cloud@childScript"]:30: in function <[string "Point_cloud@childScript"]:26>
[CoppeliaSim:error] External call to simCallScriptFunction failed (PcMessage_callback): Error in script function.
stack traceback:
stack traceback:
[sandboxScript:info] simulation stopping...
stack traceback:
[sandboxScript:info] Simulation stopped.
And my camera is Azure kinect dk, and it will offer one pointcloud with 360000 points. I doubt that error was caused by the millions points?
liyinghui
Post by liyinghui »
Image. looking at rqt_graph I have get this topic in vrep. I think the problem is caused by the difference between poincloud2 and pointcloud. what should i do?
Yes, it is better to use sensor_msgs/PointCloud2. Then, make sure to enable following for the subscriber:
-- ROS:
-- ROS2:
simROS2.subscriptionTreatUInt8ArrayAsString(sub)
Then convert the returned array to a table with sim.unpackFloatTable
liyinghui
Post by liyinghui »
I followed your instruction, but i still get the errors like that:
 31: attempt to index field 'points' (a nil value)
    stack traceback:
        [string "Point_cloud@childScript"]:31: in function <[string "Point_cloud@childScript"]:26>
It is seemed like the unpack processing is wrong.
This is the code I have now:
    if simROS then
    local pts={}
    pts=sim.unpackFloatTable(pts)
    if simROS then
I'd appreciate if you can give more help!!!
You are mixing up PointCloud and PointCloud2 messages!
liyinghui
Post by liyinghui »
https://youtu.be/KWXOJPNQjB4
Thanks Gods,I finally get the pointcloud in vrep, but unluckily there is a few errors still, It seems like that the pointcloud is duplicated, what wrongs have i made?
    if simROS then
    data=sim.unpackFloatTable(msg.data)
    --local pts={}
    --for i=1,#data/3,1 do
       -- pts[#pts+1]={data[i],data[i+1],data[i+2]}
    --end
    sim.insertPointsIntoPointCloud(pc,0,data,{0,255,0})
    if simROS then
liyinghui
Post by liyinghui »
I m struggle with how to get the real data from pointcloud2 msg. I could not get it from the msg.data. how should i code?
sensor_msgs/PointCloud2 is a binary format.
The data field is a sequence of bytes (in CoppeliaSim that may come as uint8 array or a string, depending on the subscriber settings). Information to decode it is contained in the other fields of the message (is_bigendian, fields, point_step, row_step, ...).
Refer to the message documentation for more info.
In CoppeliaSim, Packing/unpacking functions may be useful.
