Editing child scripts with VScode
mthor13
Contact:
Post by mthor13 »
Hi Coppelia & Everyone else,
Does anyone have a trick or solution for including the sim and simROS2 libs when editing python child scripts in VScode?
Currently, VScode does not recognize either sim and simROS2 (see https://imgur.com/rrPWKnC), but I would like to use the IDE functionality to get suggestions when using the two libraries and avoid import errors.
All the best,
Mathias Thor
Re: Editing child scripts with VScode
Hello Mathias,
have a look at the add-on generate notepad++ files (maybe also in the exporters section of Modules). That add-on is basically fetching all the API functions and constants, and generating 2 files compatible with notepad++, to provide code completion and call tips. By slightly adjusting that add-on, you can probably generate a VScode extension file for API functions/variables that you need. You'll have to search how to extend VS' intelliSense, probably just a matter of adding or modifying a json file.
mthor13
Contact:
Post by mthor13 »
Thanks!
