consider a point in the environment of coppeliasim. This point's coordinates are represented by a pixel in an image from a vision sensor. The pixel in an image from an orthogonal sensor, (x1,y1). The pixel of the same point in a perspective image is (x2,y2). Is there a mathematical or coppelisim way to relate (x1,y1) to (x2,y2)?
cheers,
relationship of perspective and orthogonal sensors
Re: relationship of perspective and orthogonal sensors
Have a look at the demo model in modelLibrary/components/sensors/Camera pixels to 3D positions.ttm: in there you will see the relationship between world coordinates and image coordinates, for a vision sensor in perspective projection mode. The sensor offers 2 calculation methods. Method2 is more intuitive, but slowlier. This is the relevant code:
For a vision sensor in orthogonal mode, things are easier.
function sysCall_sensing()
if not builtInCalculation then
-- with method 2:
local m=sim.getObjectMatrix(sensor,sim.handle_world)
sim.addDrawingObjectItem(pointContainer,nil)
local depthMap=sim.getVisionSensorDepth(sensor,1)
depthMap=sim.unpackFloatTable(depthMap)
local cols
if pointsHaveColor then
cols=sim.getVisionSensorImg(sensor)
cols=sim.unpackUInt8Table(cols)
for y=0,resY-1,1 do
for x=0,resX-1,1 do
local ind=y*resY+x+1
local d=depthMap[ind]
local coord={0,0,d}
coord[1]=d*math.tan(xAngle*0.5)*(0.5-(x/(resX-1)))/0.5
coord[2]=d*math.tan(yAngle*0.5)*((y/(resY-1))-0.5)/0.5
coord=sim.multiplyVector(m,coord)
coord[4]=cols[3*(ind-1)+1]
coord[5]=cols[3*(ind-1)+2]
coord[6]=cols[3*(ind-1)+3]
sim.addDrawingObjectItem(pointContainer,coord)
I see. So this is it right?
could you please elaborate on parameters ?
thanks
xAngle, yAngle, resX, resY
thanks
Hello Coppeliasim,
I'm sorry for the inconvenience but I really can't understand the d, xAngle, and yAngle parameters in the answer you provided for me. Could you please explain them?
xAngle: that is the horizontal view angle
yAngle: the vertical view angle
d: the distance to the object corresponding to that specific pixel, in meter
The idea is to iterate over all pixels, and via simple trigonometric calculations, extract for each pixel a 3D position in the world.
