What is the exact process of installing ZeroMQ for Matlab?
Fery64
Post by Fery64 »
Hi All
Given the explanations in this link are so scarce on https://www.coppeliarobotics.com/helpFi ... erview.htm
and the comments on this link in Mathworks show that the installation of ZeroMQ is not that easy.
https://de.mathworks.com/matlabcentral/ ... -of-zeromq
where can I find a clear and precise explanation on how to install the ZeroMQ : on the first link it is written :
pkg install -forge communications
pkg install -forge zeromq
but it is not mentioned on CoppeliaSim terminal or on Matlab
Re: What is the exact process of installing ZeroMQ for Matlab?
Read more carefully the docs.
You don't need those steps for MATLAB.
And you don't need ZeroMQ either.
Fery64
Post by Fery64 »
Well in all my previous questions that I used remAPI I was reccommended to use ZeroMQ
For using the ZeroMQ Remote API you don't need to manually install any library in MATLAB.
(ZeroMQ is a third party library; the CoppeliaSim ZeroMQ Remote API is a different package, provided by Coppelia Robotics)
