Object Quaternion on ZMQ???
Fery64
Post by Fery64 »
Hi All
Since in most answers, I am inspired to use ZMQ libraray, I tried to look into its libraray elements: there are no phrases in common with the remAPI!!! so how should I know which function I need to use???!!!
http://api.zeromq.org/master:_start
There is no seach button in its website, and no way to compare the functions with Lua!!!!
I want to know if ZeroMQ has
sim.GetObjectQuaternion
and
sim.GetObjectPosition
or not
Re: Object Quaternion on ZMQ???
Starting point for documentation:
ZeroMQ remote API.
You don't need to use the ZeroMQ library. That is a third-party library internally used by ZeroMQ Remote API.
