Can not build simExtRos plugin
pme1976
Post by pme1976 »
Hello. I can not build simExtRos plugin. There are many errors like this:
/home/user/install/CoppeliaSim_Edu_V4_4_0_rev0_Ubuntu20_04/programming/libPlugin/simPlusPlus/Lib.cpp: In function ‘int sim::getStackBoolValue(int, bool*)’:
/home/user/install/CoppeliaSim_Edu_V4_4_0_rev0_Ubuntu20_04/programming/libPlugin/simPlusPlus/Lib.cpp:281:49: error: cannot convert ‘bool*’ to ‘simBool*’ {aka ‘unsigned char*’} in argument passing
281 | int ret = simGetStackBoolValue(stackHandle, boolValue);
| bool*
Re: Can not build simExtRos plugin
please use the correct branch, e.g. if you are running CoppeliaSim V4.4, then do:
git clone -b coppeliasim-v4.4.0-rev0 https://github.com/CoppeliaRobotics/simExtROS
pme1976
Post by pme1976 »
I try, but the error remains.
did you clone following repos in the same way?
  • include
  • common
  • libPlugin
  • (simMath)
pme1976
Post by pme1976 »
Thank you so much for your help.
I have built the plugin. Most likely I missed one of the steps when building the plugin.
