How to move the deformable targets by suction tools
Keven Sun
Post by Keven Sun »
I'm trying to move a softbox and a cloth by UR5 with a suction tool. The deformable targets are easily created under MuJoCo, but it seems that they cannot be sucked up by the tool.
Is there any feasible solution to achieve this goal?
thanks a lot.
Re: How to move the deformable targets by suction tools
you will have to attach the composite to another object via an equality constraint. E.g. in case of a softBody composite (cuboid), something like:
        xml='<connect body1="'..prefix..'" '
        xml=xml..' body2="'..sim.getObjectAlias(sim.getObject('/Floor'),4)..'"'
        xml=xml..' anchor="0 0 0"/>'
        simMujoco.injectXML(xml,'equality')
You wil have to compute the correct anchor point at the point of attachment though.
Keven Sun
Post by Keven Sun »
Thanks for your help, it works!
One more question, It seems that the constraint should be set in sysCall_init() function. Can I remove this constraint when the softbox is dropped by tools? Further, can the xml be modified during simulation, for example, remove the constraint mentioned above, or add <pin coord> for cloth?
Thanks!
Yes, you can remove this constraint or composite via simMujoco.removeXML. You can also correctly regenerate such a constraint via a callback mechanism. That will be available in CoppeliaSim V4.5
If you tell me your platform, then we will provide a beta version.
Keven Sun
Post by Keven Sun »
Thanks for your help. My platform is ubuntu 20.04. I can't wait to try the beta version!
You can find the beta versions here. Keep in mind that only the Ubuntu20 file has the features you are looking for.
