Hi
I don't have the "Segment type" function in the "Path" tab. What can I do if I want to create a route?
https://ibb.co/wdxv9zq
Re: I don't have the "Segment type" function in the "Path" tab
see also your other post about that matter. But in short, CoppeliaSim used some paths objects in the past, that are now deprecated. You can create a new path object from a deprecated path object by selecting it, then in the object properties dialog, clicking Create similar object.
