I used the 'scaling' button in Scene Object Properties but it does not seem to work correctly. Regardless of the value I input, the object always scales up by 2 times. What am I doing wrong?
Scaling not working
Re: Scaling not working
Hello Joshua,
what OS are you on?
What happens if you change the scaling value and then press tab before clicking OK?
In any case, you can also scale objects/models with the isometric scaling tool located at: Models/tools/isometric scaling tool.ttm
what OS are you on?
I'm using Mac OS X Yosemite. I realised that if I clicked on the 'OK' button, it will always scale the object by 2. However, if I press 'Enter' on the keyboard, then it works fine.
Oh, yes, that's very possible that Mac operates slightly differently than the other platforms...
