License dongle not found in WSL2 environment
I am trying to use CoppeliaSim Pro inside WSL2, but am having trouble finding dongle during intialization. I am using usb passthrough method described here https://learn.microsoft.com/en-us/windo ... onnect-usb. I wonder if there is anything I am missing here.
Re: License dongle not found in WSL2 environment
try with following (from the readme.txt):
a) $ lsusb
b) Make sure that the dongle is correctly plugged
and recognized (VID:1bc0, PID:8100)
c) $ sudo cp 92-SLKey-HID.rules /etc/udev/rules.d/
d) Restart the computer
e) $ ./coppeliaSim or alternatively ./coppeliaSim.sh
Thank you for the response. Yes, I have followed the instructions in readme.txt, however, I am still getting "no dongle found" during CoppeliaSim initialization. I am running version v4.1.0.
The dongle should be blinking when initialized by CoppeliaSim. Otherwise, it means that very probably there is a problem specific to the WSL2 usb passthrough...
Thank you for the information. The dongle is not blinking when CoppeliaSim is initialized in WSL2.
What about other USB devices? Do those work?
Thank you for the response. By other USB devices, do you mean devices such as usb webcam? I tried to use Logitech USB webcam in WSL2, and it worked after building a WSL2 kernel with the appropriate driver. I am not sure if certain drivers need to be built into the kernel for the USB dongle to work.
Cheers.
Cheers.
Starting with CoppeliaSim V4.4, we also offer cloud-based licenses, that should work without a problem in your WSL2 environment..
