About floor size
About floor size
Hi guys, I hope find you all well. So, I need to know where I find some information about the blocks size on floor in a Coppelia scene? Someone can Help me with this?
Re: About floor size
the default floor is 5x5 meter. Each bright or dark patch is 0.5*0.5 meters. But that can be changed of course, e.g. if you scale the floor.
Best is probably to select the visible part of the floor, then in the shape geometry dialog, check the size of its bounding box.
