Path user configuration dialog
jwh2
Post by jwh2 »
I'm working on the BubbleRob line following tutorial and have gotten to the point about creating the path.
I opened the path's user configuration dialog to tell it to extrude the path.
Then I updated the customization script from the tutorial and restarted it.
Now I'm getting the following error:
[CoppeliaSim:error] object removal can't be triggered from within the object itself: some objects were not removed.
[/Path/Script:error] ...peliaSimEdu/lua/models/deprecated/path_customization.lua:513: attempt to index a nil value (field 'paths')
stack traceback:
...peliaSimEdu/lua/models/deprecated/path_customization.lua:513: in function 'path_customization.setup'
(...tail calls...)
...peliaSimEdu/lua/models/deprecated/path_customization.lua:4: in function 'sysCall_init'
In addition, I don't see the three bar icon for the path's user configuration dialog anymore.
Any thoughts?
Re: Path user configuration dialog
if you are running CoppeliaSim V4.7, then you should fix the script content and instead of
path = require('path_customization')
do
path = require('models.path_customization')
But you are right, the tutorial is not up-to-date for CoppeliaSim V4.7
