How can I change the port number? (ZeroMQ API - python)
wenyu
Post by wenyu »
Hello!
I use the ZeroMQ remote API for Python. How can I change the port number?
python :
client = RemoteAPIClient(host='localhost', port=23005)
sim = client.getObject('sim')
But I don't know how to change the corresponding port number in vrep V4.5.
Thanks.
Re: How can I change the port number? (ZeroMQ API - python)
You can start CoppeliaSim passing the command line parameter -GzmqRemoteApi.rpcPort=23005.
Or with CoppeliaSim already started, execute sim.setNamedInt32Param('zmqRemoteApi.rpcPort',23005) (e.g. in the lua commander at bottom of screen) and then restart the ZMQ Remote API server addon.
wenyu
Post by wenyu »
Thanks for your reply, but it doesn't work.
execute sim.setNamedInt32Param('zmqRemoteApi.rpcPort',23005), and restart python program. The robot doesn't respond.
make sure to identify the source of the problem. When you say the robot doesn't respond, this doesn not necessarily mean that the remote API cannot communicate with CoppeliaSim. Is there an error message on the client or CoppeliaSim side, and if yes, what does it say?
fferri wrote: 05 Apr 2023, 12:36 ... and then restart the ZMQ Remote API server addon.
That is done via the menu Modules -> Connectivity -> ZMQ Remote API Server
wenyu
Post by wenyu »
Thanks for your reply. It helped me a lot.
thumengql
Post by thumengql »
For me, the -Gxx parameter does not work.
I used
coppeliaSim.exe -c"sim.setNamedStringParam('zmqRemoteApi.rpcPort',23005)"
and it works
thumengql wrote: 14 Feb 2024, 11:26 For me, the -Gxx parameter does not work.
Make sure to use the latest version of CoppeliaSim.
One of the previous 4.6.x releases had a bug with -G options.
