graphs
tttt
graphs
Post by tttt »
What should I do if I want to remotely transfer the shortest distance recorded in graphs from the robotic arm to the obstacle to matlab instead of saving it to a csv file? It's a set of distances that the robotic arm travels from moving to a stop, not one distance read by sim.simxReadDistance
Re: graphs
You can call any function defined in a child script from external programs (e.g. remote API clients).
So you can have a Lua function in a child script to make several readings and return a table of values, e.g.:
sim = require('sim')
    sensorHandle = sim.getObject('...')
    sensorData = {0, 0, 0, 0, 0, 0, 0, 0}
function sysCall_sensing()
    -- read your sensors here, e.g.:
    sensorData[1] = ...
    sensorData[2] = ...
function getSensorReadings()
    -- return last readings
    return sensorData
then use sim.callScriptFunction to remotely call the getSensorReadings function and get the returned values.
If you want to make it synchronous, to make sure not miss one simulation step, use sim.setStepping and trigger the next simulation step with sim.step.
See also the example here.
tttt
Re: graphs
Post by tttt »
hello,fferri
My lua script and matlab script are as follows. Now I want to use sim.simxCallScriptFunction in matlab to execute the sendTableToMatlab function in the lua script to return the allDistances table to the matlab side or turn it into a string signal and return it to the matlab side. It will not work. If You can directly define the values of a and b in the sendTableToMatlab function and then return it to receive it. How can I get allDistances in matlab?Thanks!
lua:
simRemoteApi.start(19999)
    -- do some initialization here
    proximitySensorHandle = sim.getDistanceHandle('myc')
    allDistances = {}
function sysCall_actuation()
    -- put your actuation code here
    recordDistances(proximitySensorHandle)
    -- put your sensing code here
function sysCall_cleanup()
    -- do some clean-up here
    --sendTableToMatlab(allDistances)
    --sim.setScriptAttribute(sim.handle_self, sim_customizationscriptattribute_lastbeforeinstanceswitch, "sendTableToMatlab")
function recordDistances(a)
    local result, distance = sim.readDistance(a)
    if result > 0 then
        table.insert(allDistances, distance)
function sendTableToMatlab(inInts, inFloats, inStrings, inBuffer)
    local distancesString = table.concat(allDistances, ",")
    local a = 10
    sim.setStringSignal('distancesSignal', distancesString)
    print(distancesString)
    return {a},{},{distancesString},''
matlab:
clear all;
close all;
clc;
sim=remApi('remoteApi'); % 加载库函数并构建对象
sim.simxFinish(-1); % 断开所有之前的连接
clientID=sim.simxStart('127.0.0.1',19997,true,true,5000,5);  %启动链接,指向vrep中的scence,返回链接ID
if (clientID>-1)
    sim.simxStartSimulation(clientID,sim.simx_opmode_oneshot);
    [returnCode, retInts, retFloats, retStrings, retBuffer] = sim.simxCallScriptFunction(clientID, 'UR55', sim.sim_scripttype_childscript, 'sendTableToMatlab', [], [], [], '', sim.simx_opmode_blocking);
    if returnCode == sim.simx_return_ok
        disp('Distances returned from V-REP');
    [r, distancesSignal] = sim.simxGetStringSignal(clientID, 'distancesSignal', sim.simx_opmode_blocking);
    disp('Failed connecting to remote API server');
sim.simxStopSimulation(clientID,sim.simx_opmode_oneshot);
sim.delete(); % 断开连接
disp('Program ended');
Re: graphs
It is highly recommended to use the ZeroMQ remote API, since it is much easier and flexible. Additionally, you'll have access to many more API functions, than with the legacy remote API.
The legacy remote API is not supported anymore since a long time.
tttt
Re: graphs
Post by tttt »
Thanks!
