Hey Everyone,
I have a very irritating problem that keeps happening randomly. I make a CSV file of X,Y,Z points and try to import them. Only the first, sometimes the second point too gets imported. I've tried the following formats:
X,Y,Z
X,Y,Z,
X,Y,Z,A,B,G
X,Y,Z,A,B,G,
Nothing seems to work. Any help?
Thanks,
Tim
Import Path From CSV File Not Working
Re: Import Path From CSV File Not Working
Hello Tim,
do following: create a path [Menu bar --> Add --> Path --> ...] then do [Menu bar --> File --> Export --> Selected path as CSV...].
Then have a look at the generated file. Then, import it again with [Menu bar --> File --> Import --> Path from CSV...].
I have saved csv excel file on my ciomputer that I need to use to run a sim that has been created in coppelia. How do I get these files into the scene. already written in the script is
function fromCSV (s)
s = s .. ',' -- ending comma
local t = {} -- table to collect fields
local fieldstart = 1
repeat
-- next field is quoted? (start with `"'?)
if string.find(s, '^"', fieldstart) then
local a, c
local i = fieldstart
repeat
-- find closing quote
a, i, c = string.find(s, '"("?)', i+1)
until c ~= '"' -- quote not followed by quote?
if not i then error('unmatched "') end
local f = string.sub(s, fieldstart+1, i-1)
table.insert(t, (string.gsub(f, '""', '"')))
fieldstart = string.find(s, ',', i) + 1
else -- unquoted; find next comma
local nexti = string.find(s, ',', fieldstart)
table.insert(t, string.sub(s, fieldstart, nexti-1))
fieldstart = nexti + 1
until fieldstart > string.len(s)
return t
function file_exists(name)
local f=io.open(name,"r")
if f~=nil then io.close(f) return true else return false end
--- Check if a file or directory exists in this path
function exists(file)
local ok, err, code = os.rename(file, file)
if not ok then
if code == 13 then
-- Permission denied, but it exists
return true
return ok, err
function parseCSVFile(u, id)
-- Remove all previous objects
for i=numberofobj-1,1,-1 do
sim.removeObject(objhandles)
numberofobj = 1
local nodes={}
local data={}
local out=""
fname=simUI.getEditValue(ui, 1001)
if not exists(fname) then
out=string.format("Failed to find path.")
simUI.setLabelText(ui, 1003, out)
return nil
-- Import files.
local paramf = fname .. "obstacles.csv"
local dataf = fname .. "path.csv"
local nodesf = fname .. "nodes.csv"
local edgesf = fname .. "edges.csv"
-- Check if files exist.
--if not file_exists(dataf) then
--out=string.format("Failed to parse!<br>Could not find path:<br>%s",dataf)
--return nil
--end
--simUI.setLabelText(ui, 1003, out)
-- Now parse all nodes.
local i=1
local parsedLine={}
if file_exists(nodesf) then
for line in io.lines(nodesf) do
if not string.find(line, '#') and line:sub(1,1) ~= '' then
local parsedLine=fromCSV(line)
if (#parsedLine < 3) then
out=string.format("Error Parsing nodes %s: Data line %d only has %d length)<br>Raw:<br>%s",nodesf,i,#parsedLine,line)
return nil
local q={}
for j=1,#parsedLine,1 do
table.insert(q, tonumber(parsedLine[j]))
if (q[j]==nil) then
out=string.format("Failed to parse nodes %s!<br>Could not convert data line %d!<br> Raw Value=%s",nodesf,i,line)
return nil
nodes=q
i=i+1
-- Draw all nodes.
objhandles[numberofobj] = sim.createPureShape(2,16,{0.05,0,0},10,NULL)
sim.setObjectPosition(objhandles[numberofobj],-1,{q[2],q[3],0.0023})
sim.setShapeColor(objhandles[numberofobj],NULL,sim.colorcomponent_ambient_diffuse,{0,0,1})
sim.setObjectParent(objhandles[numberofobj],graphHandle,false)
numberofobj=numberofobj+1
-- Now parse all edges.
if file_exists(edgesf) then
for line in io.lines(edgesf) do
out=string.format("Error Parsing edges %s: Data line %d only has %d length)<br>Raw:<br>%s",edgesf,i,#parsedLine,line)
return nil
local q={}
if (q[j]==nil) then
out=string.format("Failed to parse edges %s!<br>Could not convert data line %d!<br> Raw Value=%s",edgesf,i,line)
return nil
-- Draw all edges.
if #nodes < q[1] or #nodes < q[2] then
out=string.format("Some nodes missing")
return nil
local difx = nodes[q[1]][2] - nodes[q[2]][2]
local dify = nodes[q[1]][3] - nodes[q[2]][3]
local midx = (nodes[q[1]][2] + nodes[q[2]][2]) / 2.0
local midy = (nodes[q[1]][3] + nodes[q[2]][3]) / 2.0
objhandles[numberofobj] = sim.createPureShape(0,16,{math.sqrt(difx ^ 2 + dify ^ 2),0.01,0},10,NULL)
sim.setObjectPosition(objhandles[numberofobj],-1,{midx,midy,0.0021})
sim.setObjectOrientation(objhandles[numberofobj],-1,{0,0,math.atan(dify / difx)})
sim.setShapeColor(objhandles[numberofobj],NULL,sim.colorcomponent_ambient_diffuse,{1,1,0})
-- Now parse all obstacles.
if file_exists(paramf) then
for line in io.lines(paramf) do
out=string.format("Error Parsing obstacles %s: Data line %d only has %d length)<br>Raw:<br>%s",paramf,i,#parsedLine,line)
return nil
local q={}
if (q[j]==nil) then
out=string.format("Failed to parse obstacles %s!<br>Could not convert data line %d!<br> Raw Value=%s",paramf,i,line)
return nil
-- Draw all obstacles.
objhandles[numberofobj] = sim.createPureShape(2,26,{q[3],0,0.03},10,NULL)
sim.setObjectPosition(objhandles[numberofobj],-1,{q[1],q[2],0.015})
sim.setObjectParent(objhandles[numberofobj],envHandle,false)
-- Now parse the path.
if file_exists(dataf) then
for line in io.lines(dataf) do
local q={}
if (q[j]==nil) then
out=string.format("Failed to parse path %s!<br>Could not convert data line %d!<br> Raw Value=%s",dataf,i,line)
return nil
if #nodes < q[j] then
return nil
data[j] = {nodes[q[j]][2], nodes[q[j]][3]}
-- Draw path.
if j > 1 then
pathEdgeL[j-1] = math.sqrt((data[j][1] - data[j-1][1]) ^ 2 + (data[j][2] - data[j-1][2]) ^ 2)
local difx = nodes[q[j]][2] - nodes[q[j-1]][2]
local dify = nodes[q[j]][3] - nodes[q[j-1]][3]
local midx = (nodes[q[j]][2] + nodes[q[j-1]][2]) / 2.0
local midy = (nodes[q[j]][3] + nodes[q[j-1]][3]) / 2.0
objhandles[numberofobj] = sim.createPureShape(0,16,{pathEdgeL[j-1],0.02,0},10,NULL)
sim.setObjectPosition(objhandles[numberofobj],-1,{midx,midy,0.0022})
sim.setShapeColor(objhandles[numberofobj],NULL,sim.colorcomponent_ambient_diffuse,{0,0.5,0})
if j == 2 then pathPassedL[1] = pathEdgeL[1] end
if j > 2 then pathPassedL[j-1] = pathPassedL[j-2] + pathEdgeL[j-1] end
totalLength = pathPassedL[#pathEdgeL]
jointData=data
if #jointData <= 1 then
totalLength = 0.0
out=string.format("No available path")
out=string.format("Successfully parsed file!<br>File path = %s<br>Data count = %d",fname,i-1)
-- Begin and end nodes.
if #jointData > 0 then
sim.setObjectPosition(objhandles[numberofobj],-1,{jointData[1][1],jointData[1][2],0.0024})
if #jointData > 1 then
sim.setObjectPosition(objhandles[numberofobj],-1,{jointData[#jointData][1],jointData[#jointData][2],0.0024})
sim.setShapeColor(objhandles[numberofobj],NULL,sim.colorcomponent_ambient_diffuse,{1,0,0})
-- Initial position.
applyJoints(jh, jointData[1])
function interpConfig(tinterp)
local t=totalLength/vel
local q={0,0}
local reset=nil
if totalLength == 0 then
q = jointData[1]
thetaangle = 0.0
elseif (t<tinterp) then
tinterp = t
reset = true
for n,leng in ipairs(pathPassedL) do
if tinterp*vel <= leng then
for i=1,#q,1 do
if n == 1 then
q=jointData[n] + ((jointData[n+1]-jointData[n])/pathEdgeL[n])*(tinterp*vel)
q=jointData[n] + ((jointData[n+1]-jointData[n])/pathEdgeL[n])*(tinterp*vel-pathPassedL[n-1])
thetaangle = math.atan((jointData[n+1][2]-jointData[n][2])/(jointData[n+1][1]-jointData[n][1]))
if jointData[n+1][1] < jointData[n][1] then
thetaangle = thetaangle - math.pi
break
return reset,q,thetaangle
function setTimeSliderValue(ui,t)
local fraction=t/totalLength*vel
simUI.setSliderValue(ui,4000,10000*fraction,true)
return
function playPressed(ui,id)
local out=nil
if not jointData then
out=string.format("WARN: No file loaded, cannot play!")
return
if (playbackStatus==status.stop) then
startTime=sim.getSimulationTime()
out=string.format("Playback started from beginning!")
playbackStatus=status.play
elseif (playbackStatus==status.pause) then
local tfrac=simUI.getSliderValue(ui,4000)/10000
startTime=sim.getSimulationTime()-tfrac*totalLength/vel
out=string.format("Playback resuming from pause!")
function pausePressed(ui,id)
if (playbackStatus==status.play) then
out=string.format("Playback paused!")
playbackStatus=status.pause
function stopPressed(ui,id)
out=string.format("Playback stopped!")
playbackStatus=status.stop
setTimeSliderValue(ui, 0.0)
if jointData then
local reset,q,thetaangle = interpConfig(0.0)
applyJoints(jh,q)
sim.setJointPosition(jhx,thetaangle)
function stepPressed(ui,id)
local reset=nil
local q=nil
local tfrac=nil
local t=nil
local stepSize=nil
out=string.format("Step!")
--if (interpFlag) then
tfrac=tfrac+0.005
if (tfrac>=1.0) then tfrac=1.0 end
t=tfrac*totalLength/vel
reset,q,thetaangle = interpConfig(t)
--else
--stepSize=1./#jointData
--tfrac=(math.floor(tfrac/stepSize)+1)*stepSize + stepSize/2.
--if (tfrac>=1.0) then tfrac=0.0 end
--t=tfrac*(#jointData*nominalDT*(1/timeMult()))
--reset,q = interpConfig(jointData, t, (1/timeMult())*nominalDT)
--end
if jointData then
applyJoints(jh, q)
setTimeSliderValue(ui, t)
function timeSliderChange(ui,id,newVal)
local t=nil
local reset=nil
local q=nil
local resumePlay=false
local out=""
if (jointData == nil) then
out=string.format("Need to open CSV file!")
simUI.setSliderValue(ui,4000,0,true)
return
resumePlay=true
t=(newVal/10000)*totalLength/vel
if jointData then
applyJoints(jh, q)
if (resumePlay) then
playPressed(ui,1006)
out=string.format("Time slider dragged to %3.2f percent",newVal/10000)
return
function decreaseSpeed(ui,id)
resumePlay=true
vel=vel-multStep
if (vel <= multStep) then vel=multStep end
if (resumePlay) then playPressed(ui,1006) end
local out=string.format("%6.2f",vel)
simUI.setEditValue(ui, 1006, out)
function increaseSpeed(ui,id)
resumePlay=true
vel=vel+multStep
function parseEnteredSpeed(ui,id,newVal)
local q=tonumber(newVal)
local out=nil
if (q==nil) then
out=string.format("Could not parse entered number!")
return
elseif (q<multStep) then
q=multStep
out=string.format("Minimum multiplier value is %3.2f!",multStep)
resumePlay=true
vel=q
applyJoints=function(jointHandles, joints)
for i=1,#jointHandles,1 do
sim.setJointPosition(jointHandles[i],joints[i])
getJoints=function(jointHandles)
local angles={0,0}
angles[i]=sim.getJointPosition(jointHandles[i])
return angles
function closeEventHandler(h)
sim.addStatusbarMessage('Window '..h..' is closing...')
simUI.hide(h)
if (sim_call_type==sim.syscb_init) then
-- Check if we have a controller in the scene:
xml = [[<ui closeable="false" on-close="closeEventHandler" resizable="true">
<tabs>
<tab title="CSV Playback">
<group layout="vbox">
<label text="<big> Enter the folder path, ending with a slash/backslash:</big>" id="1000" wordwrap="false" style="font-weight: bold;"/>
<group layout="hbox">
<edit value="" id="1001" />
<button text="Open Files" on-click="parseCSVFile" id="2000" />
</group>
<label text="<big> Controls</big>" id="1005" wordwrap="false" style="font-weight: bold;"/>
<group layout="grid">
<button text="Play" on-click="playPressed" />
<button text="Pause" on-click="pausePressed" />
<button text="Stop" on-click="stopPressed" />
<button text="Step" on-click="stepPressed" />
<br/>
<label text="Time Multiplier" />
<button text="Increase" on-click="increaseSpeed" />
<button text="Decrease" on-click="decreaseSpeed" />
<edit id="1006" value="0.1" oneditingfinished="parseEnteredSpeed" />
</group>
<label text="Time" />
<hslider id="4000" tick-position="below" tick-interval="500" minimum="0" maximum="10000" on-change="timeSliderChange"/>
<label text="<big> Messages:</big>" id="1002" wordwrap="false" style="font-weight: bold;"/>
<label value="" id="1003" wordwrap="true" />
</group>
</group>
<stretch />
</tab>
</tabs>
</ui>]]
ui=simUI.create(xml)
-- get joints:
jh={-1,-1}
jh[1] = sim.getObjectHandle('World_x_joint')
jh[2] = sim.getObjectHandle('World_y_joint')
jhx = sim.getObjectHandle('World_theta_joint')
envHandle=sim.getObjectHandle('env')
graphHandle=sim.getObjectHandle('graph')
kilobotHandle=sim.getObjectHandle('KilobotD')
multStep=0.02
jointData={}
vel = 0.1
pathEdgeL={}
pathPassedL = {}
totalLength = 0.0
objhandles={}
numberofobj=1
fname=""
startTime=0.0
-- flags
status={stop=0, play=1, pause=2}
delayCount=0
delayRefCount=60
if (sim_call_type==sim.syscb_actuation) then
local t=0.0
local reset=nil
local q=nil
local thetaangle=0.0
t=(sim.getSimulationTime()-startTime)
if (jointData) then
if reset and #jointData > 0 then
if (delayCount>=delayRefCount) then
delayCount=delayCount+1
out=string.format("Animation reset!")
if (delayCount>=2*delayRefCount) then
delayCount=0
applyJoints(jh, jointData[#jointData])
out=string.format("CSV end!")
elseif (q) then
local pre = getJoints(jh)
applyJoints(jh, q)
if (sim_call_type==sim.syscb_cleanup) then
simUI.destroy(ui)
repeat
local a, c
repeat
return t
if not ok then
if code == 13 then
return true
return ok, err
numberofobj = 1
local nodes={}
local data={}
local out=""
return nil
-- Import files.
--return nil
--end
local i=1
local parsedLine={}
return nil
local q={}
if (q[j]==nil) then
return nil
nodes=q
i=i+1
-- Draw all nodes.
return nil
local q={}
if (q[j]==nil) then
return nil
-- Draw all edges.
return nil
return nil
local q={}
if (q[j]==nil) then
return nil
local q={}
if (q[j]==nil) then
return nil
return nil
-- Draw path.
if j > 1 then
jointData=data
totalLength = 0.0
local q={0,0}
local reset=nil
q = jointData[1]
thetaangle = 0.0
tinterp = t
reset = true
for i=1,#q,1 do
if n == 1 then
break
return
local out=nil
return
if jointData then
applyJoints(jh,q)
local reset=nil
local q=nil
local tfrac=nil
local t=nil
local stepSize=nil
tfrac=tfrac+0.005
--else
--end
if jointData then
applyJoints(jh, q)
local t=nil
local reset=nil
local q=nil
local out=""
return
resumePlay=true
if jointData then
applyJoints(jh, q)
return
resumePlay=true
vel=vel-multStep
resumePlay=true
vel=vel+multStep
local out=nil
if (q==nil) then
return
q=multStep
resumePlay=true
vel=q
local angles={0,0}
return angles
simUI.hide(h)
<tabs>
</group>
<br/>
</group>
</group>
</group>
<stretch />
</tab>
</tabs>
</ui>]]
-- get joints:
jh={-1,-1}
multStep=0.02
jointData={}
vel = 0.1
pathEdgeL={}
pathPassedL = {}
totalLength = 0.0
objhandles={}
numberofobj=1
fname=""
startTime=0.0
-- flags
delayCount=0
delayRefCount=60
local t=0.0
local reset=nil
local q=nil
if (jointData) then
delayCount=0
elseif (q) then
applyJoints(jh, q)
simUI.destroy(ui)
