Reduction object
Martin_5
Reduction object
Post by Martin_5 »
Hello, Please advice how to reduce the added object.
Thanks for the advice.
Re: Reduction object
Hello Martin,
Not sure what you mean. You mean remove? In that case, select the object, then press Delete or Backspace.
Or do you mean scale the object? In that case, select the object, then click scaling in the object common properties dialog.
