Linking to OpenGL libraries on Linux (NVidia optirun primus)
dbworth
Post by dbworth »
Hi
There is a bug with the pre-compiled version of V-REP for Linux 32 and 64 bit.
It will only affect a small number of users and could potentially be fixed by compiling from source, so maybe you won't consider it a bug.
Various laptops come with a dual-mode graphics system called NVidia Optimus.
On Windows, the driver will seamlessly select either the low-power graphics adapter or the high-power 3D graphics adapter if required.
On Linux, the driver is not that advanced yet and requires manual selection of the required graphics adapter.
So typically you run a program like
# ./vrep.sh
But if you want to use the NVidia graphics adapter you must run
# optirun ./vrep.sh
I have tested this on Ubuntu 10.04.4 32-bit and 12.04.1 64-bit and the same behaviour occurs.
V-Rep throws this error when trying to execute it via optirun:
QGLContext::makeCurrent(): Cannot make invalid context current.
By enabling some debug messages using:
# export LIBGL_DEBUG=verbose
and again running:
# optirun ./vrep.sh
indicates that V-Rep is not loading because it is forcing to load libGL from /usr/lib/... instead of the NVidia version of the library in a different location, which optirun puts into LD_LIBRARY_PATH.
This thread describes a similar problem:
https://github.com/Bumblebee-Project/Bu ... issues/374
where the software program was compiled using rpath that overides the LD_LIBRARY_PATH, and thus the libraries required by optirun are ignored.
* Are you able to fix the linker settings in the pre-compiled Linux version please?
* Or can you give some recommendations on how to re-compile from source?
As a starting point, I followed the V-Rep manual and have tried to compile using the supplied v_rep.pro QT project on Ubuntu 12 64-bit.
It almost compiles, except I get an error:
'IDSN_INERTIA_FRAME' was not declared in this scope.
Grep'ing around for that name in all 4 source ZIP files it cannot be found.
* What am I doing wrong?
Also, two other users reported the same problem in:
viewtopic.php?f=5&t=227
Thank you.
Re: Linking to OpenGL libraries on Linux (NVidia optirun pri
Thank you for mentionning this. There is actually a small bug in the vrep.sh file: the LD_LIBRARY_PATH gets truncated from its current values, instead of just appending another path to it.
About your compilation error: which file is generating that error? It must be v_rep/sourceCode/dialogs/qdlgshapedyn.cpp. That file contains the only reference to IDSN_INERTIA_FRAME, and it includes v_repStrings.h at the top of the file, which itself includes v_repStringTable.h, which contains the definition of IDSN_INERTIA_FRAME. The file v_rep/v_rep.pro has the include path instruction for the string tables (INCLUDEPATH += "sourceCode/strings"). It should be able to find the reference to IDSN_INERTIA_FRAME.
dbworth
Post by dbworth »
Hi
Thanks for your quick reply.
* Would it be possible to update the Linux binary on the download site please?
Yes all that information is correct... but the #define is missing from v_repStringTable.h in the source download zip file.
Actually, I was able to proceed further adding the following 2 missing defines to v_repStringTable.h :
#define IDSN_INERTIA_FRAME "sometext"
#define IDSN_INERTIA_FRAME_RELATIVE_TO_WORLD "sometext"
Also I got various errors for:
'CSensingThreadPool' has not been declared
I had to add:
#include "sensingThreadPool.h"
to:
sourceCode/collisions/RegColl.cpp
sourceCode/distances/RegDist.cpp
sourceCode/3dObjects/proximitySensor.cpp
Now I'm getting an error about a header file from QScintilla.
Actually, I installed all the requirements listed on the "Compiling V-REP" webpage using the package manager for Ubuntu 12.
But it seems the packages for libqscintilla2-*** (which is version 2.6) don't include all the required headers, so I will have to try compiling QScintilla 2.7 manually...
You are right, there was a mix-up that happended at some stage. Here the missing defines:
#define IDSN_INERTIA_FRAME "Inertia frame"
#define IDSN_INERTIA_FRAME_RELATIVE_TO_WORLD "The inertia frame is now expressed relative to the absolute reference frame. Clicking 'Apply to selection' will from now on apply the same absolute position/orientation of the inertia frames."
Also about the other error, just add #include "sensingThreadPool.h" at the top of the file. I guess you might find some other similar problems (e.g. same problem in file RegDist.cpp). Sorry about the trouble, we are working with several versions in parallel...
dbworth
Post by dbworth »
Ok so to run V-REP on my system, I edited vrep.sh like so:
#LD_LIBRARY_PATH=$dirname # (don't need this line)
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$dirname # change this line
So I can now run:
# optirun ./vrep.sh
or
#primusrun ./vrep.sh
Also, I was able to successfully compile V-REP.
I installed all the required packages from Ubuntu sources, but compiled QScintilla 2.7 manually.
Hower that still doesn't put the required header file in a useful location like /usr/include/
V-REP seems to rely on at least SciLexer.h, so I had to include the directory where that was extracted too /home/user/Downloads/QScintilla-gpl-2.7/
Perhaps this header file could just be included with V-REP ?
Thankyou for your help.
Also, I thought it would be helpful for other users to have a compilation guide for the recommended Linux platform:
How to compile V-REP on Ubuntu Precise 12.04.2 LTS 64-bit
Note this was actually done using LUbuntu 12.04.2, which is almost the same but with a low graphics desktop.
If you can, run V-REP once:
# ./vrep.sh
Check the About menu to see what version of Qt you have installed:
V-Rep Edu v 3.0.3
QT v 4.8.1
bullet 2.78
ode 0.12
build apr 26 2013
Download fresh copy of V-REP EDU.
Download V-REP source, extract, and put "v_rep" directory into the "V-REP_PRO_EDU_V3_0_3_64_Linux" directory.
Check what version of Qt4 is available from Ubuntu repo:
# sudo aptitude show libqt4-core
e.g. v4.8.1
which is what we want
Install dependencies:
# sudo apt-get install qt4-dev-tools libqt4-dev libqt4-core libqt4-gui
# sudo apt-get install lua5.1 lua5.1-doc lua5.1-lgi lua5.1-lgi-dev lua5.1-policy lua5.1-policy-dev
# sudo apt-get install liblua5.1-0 liblua5.1-0-dbg liblua5.1-0-dev liblua5.1-dev
# sudo apt-get install libboost-all-dev
# sudo apt-get  install qtcreator qtcreator-dbg qtcreator-doc
(Don't install QSctintilla2 from repo, it doesn't include the header files we need)
Download QScintilla-gpl-2.7.1.tar.gz
from here
http://www.riverbankcomputing.com/softw ... a/download
Fix the directory permisions and compile:
# chown -R username:username QScintilla-gpl-2.7.1/
# cd Qt4Qt5
# qmake qscintilla.pro
# make
# sudo make install
Check what version of Qt that QMake is using:
# qmake -v
QMake version 2.01a
Using Qt version 4.8.1 in /usr/lib/x86_64-linux-gnu
which is what we want.
In the V-REP source directory, edit
v_rep.pro
Edit the Unix block to something like:
unix:!macx {
	INCLUDEPATH += /usr/lib                               // Boost directory
	INCLUDEPATH += /usr/include/qt4                       // QScintilla "Qt4" directory
	INCLUDEPATH += /usr/include/qt4/Qsci                                   // QScintilla "include" directory
        INCLUDEPATH += /home/USERNAME/Downloads/QScintilla-gpl-2.7.1/include   // for SciLexer.h
        LIBS += /usr/lib/x86_64-linux-gnu/libqscintilla2.so                    // QScintilla2 library
	contains(QMAKE_HOST.arch, x86_64):{                          // 64 Bit
		INCLUDEPATH += /usr/include/lua5.1                   // lua5.1 64"include" folder**
		LIBS += -Llua5_1_4_Linux26g4_64_lib/ -llua5.1
		DEFINES += QT_VREP_64BIT
	!contains(QMAKE_HOST.arch, x86_64):{                        // 32 Bit
		INCLUDEPATH += /usr/include/lua5.1                  // lua5.1 32"include" folder**
		LIBS += -Llua5_1_4_Linux26g4_lib/ -llua5.1
	DEFINES += LIN_VREP
Also change these 3 lines, from the top one (incorrect) to the one below:
#sourceCode/communication/serial_mac_linux.h \
sourceCode/communication/serialPort/serial_mac_linux.h \
#sourceCode/geometricAlgorithms/algos/MeshRoutines.h \
sourceCode/geometricAlgorithms/MeshRoutines.h \
#HEADERS += sourceCode/various/vrepConfig  \
HEADERS += sourceCode/various/vrepConfig.h  \
Make some corrections to the source code:
Edit this file:
v_rep/sourceCode/strings/v_repStringTable.h
add the following 2 lines:
Edit these 3 files:
v_rep/sourceCode/collisions/RegColl.cpp
v_rep/sourceCode/distances/RegDist.cpp
v_rep/sourceCode/3dObjects/proximitySensor.cpp
add the following include:
Now compile V-REP:
Run QT4 Creator
and load the project file v_rep.pro from
V-REP_PRO_EDU_V3_0_3_64_Linux/v_rep/
or go to that same directory and run:
# qmake v_rep.pro
# make
# sudo make install
Which should install /usr/lib/libv_rep.so***
Thanks a lot for the very detailed instructions!
We'll try to include them for next release.
