ROS Interface message type
BlueSkeptical
Post by BlueSkeptical »
Hi all, i'll try to explain what's my problem.
My simulation need to publish to comand_msgs/FollowJointTrajectoryActionGoal topic so i created a publisher doing:
pub = simROS.advertise('/my_topic/follow_joint_trajectory/goal', 'control_msgs/FollowJointTrajectoryActionGoal')
After i run the simulation, an error occurs:
unsupported message type. please edit and recompile ROS plugin (simROS.advertise @ 'RosInterface' plugin)
So i downloaded fferri ROS Interface plugin into my ros_workspace/src/ folder, edited messages.txt by adding this line:
Then catkin build and everything compiled with no error. What should i do now? I tried to copy the file libsimExtROSInterface.so i found in ros_workspace/devel/lib into CoppeliaSim main directory but the simulation keeps telling me:
I don't know what to do. I'm using ROS kinetic on Ubuntu 16.04
Re: ROS Interface message type
if you are trying to do:
then the message you need to add in meta/messages.txt is:
BlueSkeptical
Hi, thanks for the reply.
I tried but during catkin build this error occurs:
Errors     << sim_ros_interface:make /home/j/ros_ws/logs/sim_ros_interface/build.make.017.log
/home/j/ros_ws/build/sim_ros_interface/generated/ros_msg_io.cpp: In function ‘void write__control_msgs__FollowJointTrajectoryActionGoal(const FollowJointTrajectoryActionGoal&, int, const WriteOptions*)’:
/home/j/ros_ws/build/sim_ros_interface/generated/ros_msg_io.cpp:20135:66: error: ‘write__actionlib_msgs__GoalID’ was not declared in this scope
             write__actionlib_msgs__GoalID(msg.goal_id, stack, opt);
/home/j/ros_ws/build/sim_ros_interface/generated/ros_msg_io.cpp:20148:80: error: ‘write__control_msgs__FollowJointTrajectoryGoal’ was not declared in this scope
             write__control_msgs__FollowJointTrajectoryGoal(msg.goal, stack, opt);
/home/j/ros_ws/build/sim_ros_interface/generated/ros_msg_io.cpp: In function ‘void read__control_msgs__FollowJointTrajectoryActionGoal(int, control_msgs::FollowJointTrajectoryActionGoal*, const ReadOptions*)’:
/home/j/ros_ws/build/sim_ros_interface/generated/ros_msg_io.cpp:20210:81: error: ‘read__actionlib_msgs__GoalID’ was not declared in this scope
                         read__actionlib_msgs__GoalID(stack, &(msg->goal_id), opt);
/home/j/ros_ws/build/sim_ros_interface/generated/ros_msg_io.cpp:20224:95: error: ‘read__control_msgs__FollowJointTrajectoryGoal’ was not declared in this scope
                         read__control_msgs__FollowJointTrajectoryGoal(stack, &(msg->goal), opt);
make[2]: *** [CMakeFiles/simExtROSInterface.dir/generated/ros_msg_io.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [CMakeFiles/simExtROSInterface.dir/all] Error 2
make: *** [all] Error 2
That happens because the message you added depends on another message (actionlib_msgs/GoalID), which is not present in meta/messages.txt. Unfortunately the build system does not resolve those dependencies automatically: you have to list all the relevant messages.
BlueSkeptical
Really thank you, now it works! I added:
control_msgs/FollowJointTrajectoryGoal
