Macbook Air M1 compatibility and efficiency
zhy149
Post by zhy149 »
Hello, it seems that when I try to start remote api from the server side, the script runs very slow and gets stuck always. Also, it responds very slowly when I stop the simulation. I'm thinking perhaps it's because of an operating system compatibility issue. Can anyone give me some hints on this? I'm on Monterey operating system.
Thanks in advance!
Re: Macbook Air M1 compatibility and efficiency
which remote API and what language are you using? If using Python, I highly recommend to use the ZeroMQ-based remote API. Please try with that one and see if the problem persists. Additionally, try to keep CoppeliaSim in the foreground and see if that makes a difference. On macOS there can be glitches linked to that.
zhy149
Post by zhy149 »
coppelia wrote: 11 Jan 2022, 08:26 Hello,
Hi, I use python yes. I'll try this and let you know if there is any error, thank you!
