Dynamic conveyor belt
lydie
Post by lydie »
I would like to put a conveyor belt (generic conveyor) on the top of the mobile robot Pioneer_p3dx. However, the conveyor belt is not dynamic so when I assembled the conveyor with the robot and I ran the model, I got a message saying "it appears there is at least 1 static respondable shape built on top of a dynamic tree structure...". So, I tried to check the box "body is dynamic" of all the conveyor_pad and of the conveyor_shape. I don't have the message anymore, but the result is not the one expected. The behave of the conveyor belt when I run the simulation is strange: the conveyor pads are ok but the conveyor shape is not following the robot and ended up falling. I tried to change its mass, like it said in the tutorial, but nothing change. How could I do to keep the conveyor dynamic with a normal behave (following the robot). Is it important to put the conveyor in dynamic mode, or it could work with the static one?
Thank you in advance,
Lydie Jay
Re: Dynamic conveyor belt
this is the normal behaviour of those conveyors. If you need a conveyor whose base is attached to a dynamically enabled object, then you need to adjust your approach, and use joints and cylinders to simulate the belt, similar to the caterpillar model in Models/components/locomotion and propulsion/caterpillar.ttm (e.g. you can attach the caterpillar model to one of the Pioneer's force/torque sensor).
The reason for that is that you need a joint to propulse a dynamically enabled shape.
You can of course also attach a static conveyor on top of a mobile robot, but then the conveyor will not influence the robot whatsoever, even if the conveyor collides with a static wall, etc.
