CoppeliaSim 4.3.0 install problem
erdem01
Post by erdem01 »
I am installing the new version CoppeliaSim 4.3.0. But the C:\Program Files\CoppeliaRobotics\CoppeliaSimEdu is empty. It runs when the installing is finished. But then there is no CoppeliaSim exe to start the program again. I didn't have any problem like this with 4.2.0 version. But I deleted that version to install 4.3.0. But I regret to install 4.3.0 version.
Re: CoppeliaSim 4.3.0 install problem
something must have gone wrong with the installation. CoppeliaSim uses QSetup, and we never had any problems with that. In that regard, there is also no difference with previous CoppeliaSim versions. Make sure that your system is supported and does not have anything special about it. Maybe try to run the installer via admin priviledges.
Finally, if nothing works, simply download the binaries, that you can place anywhere on your machine. You'll just have to run the <installFolder>/vcredist/vc2019redist_x64.exe
You can select a specific download package by clicking on Want to choose a different platform on the download page.
