Fix scale of graph
MIFBob
Fix scale of graph
Post by MIFBob »
How can you fix the scale of a graph?
I want to plot joint values and see quickly how close they are to joint limits - say as a % for instance
I saw a post from 2014 saying that it should be possible to do fix the graph scale in subsequent releases but I cannot seem to find how to do this.
I can plot the data ok but the scale also dynamically changes based upon the value of the data values, hence me wanting to fix the axes scale.
I am using CoppeliaSim Edu version 4.4.0
Any help gratefully appreciated. - Thanks.
Re: Fix scale of graph
when plotting data in a graph, you are fully in charge what point you want to display. You basically add new points via sim.setGraphStreamValue. If you select an X/Y graph to plot your data, then you can provide the X and Y values for a point, and discard points that are of no interest. Kind of filtering your values. By doing so, you should be able to have a better view onto data that is of interest for you.
MIFBob
Post by MIFBob »
Thank you but what I was after was a Fixed Y Scale, nothing to do with the points that are plotted on this scale.
When I plot points; say y=1 and y=10 with x being the time, then the graph currently auto scales the y axis when the y=10 is plotted.
This is the functionality I wish to turn off.
What I want here is to always plot a y scale of say max 15, min -5.
Thanks.
Ok, then you will have to handle the graph yourself, by creating a custom graph. Have a look at the example in scenes/customUI.ttt: in the dialog that pops open when simulation starts there is a Plot tab. See the related code around line 260 in the child script attached the object Script
MIFBob
Post by MIFBob »
Thank you I will look into that.
